Good morning guys.
My VW Polo 1.6 TDI starts to have the glow plug light flashing every time after continuously driving some 60 kilometers or so.
The car pulls fine and no abnormal sounds noticed. If you switch it off for five minutes and restarts the light stops flashing until the next 60 kilometers of continuous driving.
Any assistance will be appreciated.
Sent from my SM-A307FN using Tapatalk
Glow plug light flashing 1.6tdi
- Car Model: Polo 1.6 TDI
- CLN1.6TDI FK
- Registered for: 2 years 10 months
- Car Make: VW Cross Polo
- Car Model: Cross Polo Mk5 1.6 tdi 77Kw
Re: Glow plug light flashing 1.6tdi
Hi PeterTech
Check you glow plugs, you might have a dead or dying glow plug.
I have a 1.6 Tdi CR and had a similar issue, found glow plug nr. 1 was dead.
You can test it with a multi meter. My good glowp plugs gave a 1.7 ohm reading the dead one 35.9 ohm. You can easily test from your glow plug controller connecter, it should be situated at the battery looks like a relay.
My Rides.
2008 9N3 Cross Polo 1.9 TDi
143kw 175kw on wheels.
2013 6R1 Cross Polo 1.6 TDi 77kw
1995 Golf 3, 2.0l GTI Exec
1995 Jetta 3, 2.0l Exec
1990 Jetta 2, 1.8l CLX
1979 Golf 1, 1.6l GTS
