1,9 TDI Golf V cruise control no longer working
Jambalya
Post by Jambalya »
Hey!
Does anyone know the possible cause of this?
Either the stalk or the ECU right?
Where is a good/reasonable place to get this looked at?
I live in the Sandton/Melrose area.
missioner
Car Model: '87 MK1 Golf Citi
Re: 1,9 TDI Golf V cruise control no longer working
Post by missioner »
Jambalya wrote:Hey!
Do you have an airbag light?
Rudi46
Car Make: Nike
Car Model: Walk and see more
Post by Rudi46 »
Check brake light switch and Clutch switch.
Plug in VCDS and Check values and depress pedals to see if they are working properly
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
missioner
Post by missioner »
Jambalya wrote:Hey!
We have actually failed to answer his questions properly.
Do any guys from Northern Suburbs have a good recommendation for a garage that can help the OP?
missioner
Post by missioner »
Rudi46 wrote:Check brake light switch and Clutch switch.
This is a good suggestion.
The brake light switch and the slipping on the steering column are the two most likely reasons for the system to no longer function.
Just don't go replacing parts till it's been properly checked.
Jambalya
Post by Jambalya »
Thanks Guys! My clutch was replaced quite recently. Could this have been the cause?
Jambalya
Post by Jambalya »
Rudi46 wrote: Fri Dec 31, 2021 8:53 am Check brake light switch and Clutch switch.
Thanks! will check this
Rudi46
Car Make: Nike
Post by Rudi46 »
Jambalya wrote: Wed Jan 05, 2022 6:15 pm Thanks Guys! My clutch was replaced quite recently. Could this have been the cause?
Should not be a problem unless they damaged the Clutch switch while bleeding the system. Switches sit on the pedals in the car.
They push in and twist. This adjusts the Level they work on. Maybe check if the pedal is still up high and touching the switch. Easy test is to measure with multi meter(continuity) between pins on switch and depressing pedal to see if it is still working.
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 01 Golf 4 Tdi
EX-DOHCTOR
Membership No: 712
Post by EX-DOHCTOR »
Vag Spec Centre in Randburg.
https://vagspecrandburg.co.za/
Cass
Car Model: Mk4 tdi
Post by Cass »
Mine was similiar...the swith on the clutch was broken
current: vw Golf mk4
1.9 Tdi
Ex: 92 citi rocketship (stolen)
