Polo 1.9TDI Cambelt change
Showi
Registered for: 3 years 1 month
Post by Showi »
Hi all,
Need some advice here:
I am driving a polo 1.9TDI sportline (stage 1 software and straight pipe), I am relocating to Cape Town at the end of this month and are planning on driving the car down from Pretoria.
I last did a service on 123k and the car is now on 130k, I seen the cambelt (toothed belt) was last changed at 71k in 2017, is it necessary for me to change it now before such a long drive? Also what should a cambelt replacement generally cost in todays time? (from a service center that is RMI approved and stamps the service books)
Also, I replaced CV joints on the car recently, however, I see that the front left (passenger) wheel was recently covered in grease all on the inside of the rim, what could be the problem there? Want to get some sort of idea before asking the mechanic what needs to be done.
Last thing, for a long drive such as PTA to CPT, will my car make it? What concerns are there with such a long drive on a '07 TDI with 130k Mileage? (The car has never given me any trouble to date and is running smooth and strong)
Any help and advice will be greatly appreciated.
Thanks in advance!
saxo
Re: Polo 1.9TDI Cambelt change
Post by saxo »
If you are asking all these questions then rather replace the cambelt, cv's and so on.
Nobody will know when your belt might snap, I've seen brand new replaced belts snap on 1.9 tdi's.
Cambelt service from a non rmi cost R4000 with waterpump. (Price from The Diesel Doctor)
Greenz
Car Model: Focus ST
Post by Greenz »
Showi wrote: Wed Oct 20, 2021 10:56 am Hi all,
Thanks in advance!
Take it back to whoever did the cv's.Maybe the clamps on the boots weren't put on properly or maybe the boots are torn.
2010 ST225 - 238kw 439nm
VAG Fan
Registered for: 8 years
Post by VAG Fan »
Agreed on the CVs. If the inside of the wheel is covered in grease AFTER work was done on the CVs, then simply take it back to the workshop.
Regarding the cambelt:
To quote Panic Mechanic: I don't have my crystal ball with me right now...
Jokes aside, a good rule of thumb for cambelt service intervals is 90k km and/or 6 years. Your car is still well short of that, so in principle, if the belt was correctly replaced and tensioned, it "should" be fine for some time yet. But only you yourself can put yourself at ease.
If it were mine, I'd remove the top cambelt cover and inspect the belt. If there are no signs of perishing or fraying, and if the edges of the teeth aren't overly worn, it "should" be fine.
If you do go for a cambelt change, I'd advise a change of the serpentine belt as well, including its tensioner and roller (especially if you don't know the age of these components). I had the cambelt and serpentine belt replaced on my TDI, but not the tensioner. It seized on the way back from CPT and I had to be towed home.
If the engine is maintained, a drive to CPT is absolutely no problem at all.
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
Car will make it CPT from PTA without any issues.
Just do a service including the Cambelt with tensioner.
Car is still with such loe kilos.
Sent from my SM-A307FN using Tapatalk
