Howsit
Getting a strange code on my polo. Coil light is flashing had it scanned its code P0571 which is for the brake light switch. All my brake lights work fine. Swapped the switch out (the one behind the pedal) and it still remains. Checked all the fuses and it seems fine.
Not sure what’s going on would appreciate some assistance thanks
Coil light flashing (brake light switch) problem
- Registered for: 5 years
- Car Model: Caddy MK3
- vee4410
Re: Coil light flashing (brake light switch) problem
Check the brake light bulbs. I once had an issue were one of the bulb elements shorted causing the coil light to flash.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
2004 Polo 9n 1.6
2015 MB w205 C180
