Hi
I have a 1.9 tdi Jetta 5 bxe motor with a garret turbo, not sure the model code or size, is there another turbo either in the vw range or aftermarket that is bigger that I can just bolt on without having to do any modifications to the standard stock downpipe or manifold.
surely software will have to be done after fitment I guess.
who on the forum has done this to their 1.9 tdi Jetta 5's, fitting a bigger turbo?
thanks
turbo changes
- Mr.G24
- Car Model: MK5 Jetta 1.9 TDi Comfortline
turbo changes
2008 VW Jetta 1.9 TDI Comfortline (Reflex silver)
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Carel040
Re: turbo changes
Hi there is many options to choose from the list is endless it all depends on what you want to do keep it stock or go bigger
Secondly where are u based
- Mr.G24
Re: turbo changes
@Carel040, thanks for the reply - I want to go Bigger turbo with software, but I don't want to do all the mods that you get when changing to a different or bigger turbo, and I have heard that there are stock options that is bigger than that I currently have on, but is just bolt on, no mods needed. I need to know which turbos those are with model numbers etc.
I'm in Port Elizabeth
thanks
thanks
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Carel040
Re: turbo changes
Then your best bet will be a bv39 that comes off a polo 1.9 tdi sport line very reliable turbo can handle up to 1.5 bar boost
- Mr.G24
Re: turbo changes
@Carel040, thanks for the feedback and this will be a plug and play turbo? I guess it will be bigger than my stock 1.9tdi turbo that is on my 1.9 tdi bxe jetta 5 which delivers 77kw.
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Carel040
Re: turbo changes
After software u would see around 100 105 kW nice and torque as well boost pipes should fit to
- Mr.G24
Re: turbo changes
awesome, so straight fit to existing plumbing and just bolts on in the place of my stock turbo, what a pleasure, should be an easy swop as well I think.
thanks so much, will try and source a 96kw sportline 1.9 tdi polo turbo
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Mr.G24
Re: turbo changes
hello, just a question, does the downpipe on a 96 kw tdi sportline polo fastens with a v clamp to the stock bv39b turbo or does it get bolted on the stock bv39b turbo?
my downpipe gets fastened with a v clamp to my stock garret turbo and i'm looking at the bv39b turbo as a direct replacement for my stock turbo on my 1.9 tdi jetta 5 BXE motor.
just need to know this fact before I can start to look for a bv39b turbo.
thanks
thanks
77kw @ 4000
250nm @ 1900
77kw @ 4000
250nm @ 1900
- Carel040
Re: turbo changes
U need to find the down pipe for 96kw to bolt onto the turbo don't know if the angle is the same thou
