So, the Sportline I've purchased recently came with the heater core pipes disconnected. According to the previous owner, there was a leak and so he had it blocked off (instead of getting it repaired)...
Anyyyways, winter is coming up and the wife uses the car, so I need to get the heater back in working condition. Do any of you possibly have any pics of the pipes that connect to the heater core and their respective connections? I'm trying to source some second hand pipes
Can't seem to find proper images online to give me a visual reference
Sorry, I know it may seem like a big ask and somewhat silly. Any help would be appreciated.
Just for clarity, its a 1.9 TDI ASZ motor. There is no EGR cooler, the pipes that go to the heater core have been removed.
Polo 1.9 TDI Coolant Pipes
- Registered for: 7 years
- Car Model: Polo 1.9 TDI Sportline
Jeremiah Naicker | Durban
05' VW Polo 1.9 TDI Sportline (Sold)
'06 Seat Ibiza 1.9 TDI FR (Sold)
'12 VW Jetta VI 1.2 TSI (Sold)
'15 Ford Figo 1.4 (Sold)
'01 Fiat Palio 1.2 (Sold)
'95 VW Citi Golf 1.3 (Sold)
'91 BMW 318i (Sold)
'89 Opel Kadett SR (Sold)
'91 BMW 318i (Sold)
Re: Polo 1.9 TDI Coolant Pipes
If the core is in fact leaking, the chances of your wife getting stranded somewhere due to it going pop is high.
Check this thread on how to check/repair: https://forums.tdiclub.com/index.php?th ... es.488025/
I second what @Jetta2 said. Better safe then sorry, thankfully it's easy to change over unlike other vehicles which needs a whole interior teardown.
There is two pipes going into the firewall, the heater core has a clamp type pipe fitting that can push in and it clips on, similar to some of the boost pipes and radiator hoses. To those two 90 degree clamp fittings is just normal coolant hoses, just get some from the spares shop and some clamps, you should be fine.
One pipe comes from under the tandem pump, that coolant distribution block and the other I'm not sure, I would have to double check it. I will send some photos soon when I go to the car.
Also a good idea to flush the radiator(reverse flow it with a hosepipe) and run some radiator flush as it is very easy to clog your new heater core with debris and it won't work.
Use only VW G13 coolant as well.
Apologies for the late reply, its been quite a busy few days. Thank you so much for the assistance, I'll definitely replace the core as well, like you said, better to be safe than sorry.
I'll stop by one of the spares shops this weekend and tackle everything.
Again guys, thanks so much, I appreciate it
'91 BMW 318i (Sold)
'91 BMW 318i (Sold)
