hi guys
need some assistance with my TDI.
the power steering switches off at times and it gets very difficult to turn.
some say i should top up fluid.
your thoughts.
also where is power steering fluid resevoir situated
POWER STEERING
Re: POWER STEERING
It would help to say what car you have, what model it is and what TDI engine it has.
Re: POWER STEERING
Sorry bro.
It's a 2010 polo 1.6 tdi 6r
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: POWER STEERING
Should be full servotronic i.e. electric motor setup... No power steering fluid.
Edit to add, seems there are two versions, electro hydraulic and servotronic... so you will have to find which version you have. But the below applies for both versions.
Check all connections especially ground. Also check all big fuses, probably in engine bay. Have it scanned as it should show some errors...
Check under battery for fluid reservoir, should have a green cap.
What are the symptoms? How often does it stop?
Also check stuff like steering angle sensor and it's wiring.
Re: POWER STEERING
Also make sure your car battery is still healthy. My 1.6 TDI gave me uphill with the power steering and it turned out that I had a 646CE battery (for normal petrol Polo's) instead of a 652 which is the correct battery for the diesels.
Re: POWER STEERING
Thanks it goes off when turning at low speed.
At other times it works fine, so it's on and off.
Which wiring should I check and which fuses should I look at
Re: POWER STEERING
new findings.. the power will work on a high rev
- mk2-phreak
Re: POWER STEERING
Sounds like a voltage issue. Get your battery checked out
Sent from my HD1901 using Tapatalk
