Pd100 struggle to start and sounds horrible
aristo92
Car Model: Golf MK7 GTI IS20H
Membership No: 3133
Post by aristo92 »
Hi guys,
Need some help. Recently changed the tandem pump, drove the car for 100kms then it just died. Struggles to start and when it does it sounds horrible. I have attached a link to a video for reference. https://youtu.be/l4VYbE1NFWs
Sent from my SM-G973F using Tapatalk
Regards, Armand.
Rides Thread: viewtopic.php?p=2577126#p2577126
aristo92
Membership No: 3133
Re: Pd100 struggle to start and sounds horrible
Post by aristo92 »
So I found the problem, as you can see there is scoring on the rocker arm and the cam. Will need to replace both.ImageImage
Regards, Armand.
goldwagen sells a new cam for like 1800
aristo92
Membership No: 3133
Post by aristo92 »
panic-mechanic wrote:goldwagen sells a new cam for like 1800
Thanks panic , any ideas on what could have caused this to fail like this?
Regards, Armand.
Old age, incorrect spec oil.
amstel18
Car Model: Tiguan Allspace
Post by amstel18 »
What's the mileage on that?
Almost guaranteed that motor ran on non PD spec oil for some period in its life
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
aristo92
Membership No: 3133
Post by aristo92 »
amstel18 wrote:What's the mileage on that?
Car is on 248xxxkm. So previous owners could have.
Regards, Armand.
Ashveer03
Post by Ashveer03 »
An incorrect spec oil should cause damage (even if not as bad as the proper broken one) to all 4 rollers, and the cam valve lobes aswell.
The Rocker probably just decided its the end of its life and time to fail. The Rocker arm rollers are lubed via the cam caps, into the shaft and then into the arm.
And Goodluck with the goldwagen cam
aristo92
Membership No: 3133
Post by aristo92 »
Ashveer03 wrote:An incorrect spec oil should cause damage (even if not as bad as the proper broken one) to all 4 rollers, and the cam valve lobes aswell.
And Goodluck with the goldwagen camImage
Luckily I am get decent secondhand parts. Haha but thanks again for the advice bud, it is much appreciated
Regards, Armand.
