Polo 9n3 1.9 tdi Sportline Oil recommendations
Re: Polo 9n3 1.9 tdi Sportline Oil recommendations
You get the liqui moly and service at 15k intervals, There is no benefit to short service intervals if you use low sulpher diesel (50 or less) and use a good oil.
- ICE King
In the actual book of the 9n3 polo's does it state for the diesels:
500ppm - 7500km service interval
50ppm - 15000km service interval
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Not as far as I can see...
In 2004 the most common Diesel found was 3000ppm for this the interval was set at 7500km oil changes. Then when 3000ppm were no longer available and 500ppm were the order of the day the inteval was changed to 15000km.
- ICE King
Yeah I might have it confused and you might be right , I do recall seeing a 7500km oil service for the diesel's in the book but not 100s sure the ppm. Came across it when checking for my GTI ,same book , will check this evening when I get home and report back , just for future reference.
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Also depends on software, a car that overfuels cos of a more aggressive map will contaminate the oil faster.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Castrol edge prof 5w30
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Registered for: 5 years
- Car Model: Polo 9n3 1.9 TDI Sportline
So last night I checked my cars book and could only find the below two bits of information
From the way I see it, VW set our SA models Service indicators at 15000km service intervals, This was back in the mid 2000's when these cars were introduced and 50ppm was still entering the SA market, where 500ppm was widely available already. They had to have taken into account that most people would be using 500ppm at the time and worked out that 15000km as a service interval would be safe.
So I now actually agree with panic-mechanic that 15000km service intervals are fine just use a good oil and 50ppm or lower.
But...
I also agree with MarshallGTi that if the car is modded and running software the oil may get contaminated a bit sooner and therefore a slightly shorter service interval may be beneficial.
This is just the way I see it and my 2c, please correct me if I'm wrong
But...
E92 335i N54 6MT (Rennzport Tuned), Pre LCI E90 330D (RK Motion Tuned), 9n3 Polo 1.9TDI 96kw, Golf 1 Velociti (2L 8v fully worked), Corsa Utility 1.7DTI
- ICE King
100's , I checked the book and had the exact same findings @VGTI is correct. *thumbs up*
- Stefan0909
- Car Model: Tiguan 2.0TDI
Bought my 5L yesterday at Midas for a special price of only R599
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
1.4i Velocity Stock
1.4i Kia Rio Stock
Good day
I'm still in the dark, what is 505.01 spec? e.g.10w30, etc.
I currently have Shell Helix 5w40 fully synthetic in my 1.6 TDI, does this oil fall within the 505.01 specs?
Tswerie, you are confused becuase you are trying to link the viscocity to the spec which it isn't . You can get different viscocities that will satisfy the same spec. It is really easy to see if thenoil satisfies the spec. It is printed on the bottle. If it says complies to standard 505.01 then it does.
Thanks Panic, I understand now.
- Registered for: 4 years 8 months
Anyone know this oil bizol 5w30?
It's on takelot for R360 for 5L
It's more German certified than almost anything I found and the price is pretty good
And I guess 507.00 superseded 505.00
Rather just grab a castrol for that price, it's what vw uses anyways.Twelve_ohms wrote:Anyone know this oil bizol 5w30?
From what I know, 507.00 supercedes 505.00, and not 505.01.
