VW T5 KOMBI 4TH GEAR
SechabaP
Registered for: 5 years 1 month
Post by SechabaP »
Hi there
I am looking for gear 4 of the VW T5 Kombi or transporter. Its a 1.9 TDI 2009 model. I have looked all over JHB CBD area and most gearbox shops do not have the part. I cannot afford to buy another gearbox hence I need the part only.
Any suggestions or places I can look or anyone has the spare to sell to me?
Regards
Sechaba
Stefan0909
Car Model: Tiguan 2.0TDI
Re: VW T5 KOMBI 4TH GEAR
Post by Stefan0909 »
Call Paul from Mr Gearbox 016 981 2826 and speak to him
1.4i Velocity Stock
1.4i Kia Rio Stock
1.8i VTEC Honda FRV Stock
Citroen DS3 Techno Pack Stock
SechabaP
Post by SechabaP »
Thank you Stefan, done. He will check and get back to me. Appreciate your help.
SechabaP
Post by SechabaP »
Hi Guys
Still no luck in finding the 4th gear for the VW Kombi/transporter. Any one have any idea where I can get this?
SechabaP
Post by SechabaP »
Hi Guys
Have you tied erlemanns in jhb?
SechabaP
Post by SechabaP »
yes sir I have tried Erlemanns. I also tried Delport. They dont have it.
Agents?.
SechabaP
Post by SechabaP »
Agents are bloody expensive :-)
SechabaP
Post by SechabaP »
Managed to get the 4th gear but the teeth are a bit more. Original out of the box gas 27/33 and 32 teeth. The new 2nd hand one has 32/33 and 31 teeth. Is this not going to give me issues? :-(
I think these Kombi are a problem. Nice to drive but troublesome.
don't think it will be an issue no very small ratio change
SechabaP
Post by SechabaP »
Ta panic. Will feedback once it's put together.
SechabaP
Post by SechabaP »
Good day all, what is the best gearbox oil to use for a diesel car, vw T5 Kombi and what is the best oil to use for high mileage diesel car?
Regards
use the spec quoted in the manual for the gearbox oil. being diesel has nothing to do with it,
I like liqui moly 4200 for those engines.
SechabaP
Post by SechabaP »
Hi Guys
I have just finished with the gearbox, after a week of driving the car is now taking out white smoke while driving or accelerating.
Turbo has been done, new head was put in, I dont know what else to do.
Any advise on what might be the issue now?
Pik Sooter
Car Model: MK2 Q5 3.0T l MK2 TT Roadster
Membership No: 1893
Post by Pik Sooter »
SechabaP wrote: Sun Sep 08, 2019 8:11 am Hi Guys
5L petrtol and a box of matches? :lol:
PeterTech
Car Model: Polo 1.6 TDI
Post by PeterTech »
I don't know much about cars but i had a diesel bakkie having white smoke and the problem was that the diesel was contaminated. Another time the diesel filter was clogged and after a sometime the injectors had to be fixed. Hope this helps.
Sent from my G3312 using Tapatalk
Ashveer03
Post by Ashveer03 »
Since the head was done, was the injector seals replaced? New bolts used?
T5 1.9 has an AXB engine, pretty much the same as the polos and seats. Same stuff apply, lots of info regarding Injectors and seals on here
SechabaP
Post by SechabaP »
The seal was changed after the head was done, injector were checked and tested. I will try the filter and change oil to see if there is any change.
