1.9tdi problems
- stig
- Registered for: 10 years
- Membership No: 2083
1.9tdi problems
HI guys
I have been having hard starts on my tdi. Usually when the car is warm. In the mornings on cold start it fires up as soon as I start it. When warm or hot it Wil crank for longer and then fire up. When it does fire up it sometimes sounds like it is mis firing badly, when I Rev it a bit it normalises and then have no issue further.
No lights are on or faults found on vcds.
Unrelated to this, can the ignition be Re built internally? When the car has stood in the sun for a while it is really hard to get the sterring unlocked. The key also feels very worn loosr while in the ignition.
The Ride:
H&M Dyno Night: 114KW 429NM
Re: 1.9tdi problems
Hot start issues generally caused by a faulty cam/crank sensor..
Unfortunately it can only be tested with an oscilloscope which not many people have. And no, it doesn't always throw a fault code
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Re: 1.9tdi problems
When my crank sensor died, it didn't throw a code while driving and causing the motor to cut in and out, but once the motor died altogether only then did i get a code.
I could be wrong but could possibly be a fuel issue?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- Car Model: Sportline
- Membership No: 3194
Re: 1.9tdi problems
Crank sensor.
Re: 1.9tdi problems
Ok so let's talk about that. if the crank sensor is at fault you can plug a vagcom/vcds in. Open the engine module and go to measuring blocks.
Find one (there are several) that displays the RPM value. If you crank the engine to start and it displays RPM around the 200-220 rpm range it ain't the crank sensor.
You don't need an oscilloscope to test that.
Some cars even displays the cam RPM but I have not played with the 1.9 polo enough to recall if it has that measuring block. if it does it will display half the engine rpm and that will also tell you if that sensor is OK.
the other possibility is always that nasty little thing called the engine temp sensor. They can fail with no fault code either but reading the wrong temp and making for a hard start. you can see it's value too in the blocks and look that it looks reasonable.
Does it always hard start when hot. Ie even if you have just driven it, kill and restart immediately or only if it stood a while?.
- stig
Re: 1.9tdi problems
Mostly when it stood a whilepanic-mechanic wrote:Ok so let's talk about that. if the crank sensor is at fault you can plug a vagcom/vcds in. Open the engine module and go to measuring blocks.
The Ride:
Re: 1.9tdi problems
So hard starting when it stood a while can even be leaking injectors.
SO it drips diesel in liquid form into the chamber. This has 2 results -
a mixture that does not want to ignitie until the liquid fuel has been expelled and an injector that is basically empty and has to get filled before it can spray.
But do the other checks first. IE see if the system is getting rpm when you crank it initially.
- MarshallGTi
- Car Make: Seat
Re: 1.9tdi problems
Leaky injector would give some white smoke once it does start though wont it? Once it starts pushing the half combusted diesel through the exhaust?
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Re: 1.9tdi problems
Just a thought panic, since the sensor is not completely dead it would probably be difficult to notice numbers on a scantool since the refresh rate is not quick enough..?
Leaky Injectors should give off some white smoke when started.. And the engine would run rough from all the excess fuel in the cylinder until it clears out.
A quick way of telling if injector seals are leaking, add a piece clear hose on the fuel return line inbetween the tandem pump and fuel filter, if there are continuous air bubbles in there then it's time to change seals.
Vcds block 13 might give u a clue as to which cylinders are misbehaving..
But since the car can stand the whole night and start up fine the next morning, makes it difficult to believe that it's a fueling issue as fueling issues most likely occur when the car is parked off overnight, well from what Iv seen atleast..
- stig
Re: 1.9tdi problems
Thanks for all the input guys, no white smoke. I think ill start with checking cam sensor and work from there. Will update when done
The Ride:
Re: 1.9tdi problems
I'm not talking leaky injector seal. I am talking leaky injector pintle - different leak. But if the seals in the head is leaking then the oil will get contaminated.
in vcds if you press the turbo button it ups the refresh rate and it will clearly show you a faulty crank sensor.
- MarshallGTi
- Car Make: Seat
Re: 1.9tdi problems
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- stig
Re: 1.9tdi problems
Thats crank right? Cam is behind cambelt next to rop pulley?
The Ride:
Re: 1.9tdi problems
yes
- stig
Re: 1.9tdi problems
Ordered cam sensor from lindsay saker. r1983.
I see about 300rpm when it cranks longer than normal so hopefully the cam sensor solves it
The Ride:
Re: 1.9tdi problems
U see that as crank or cam rpm?
- stig
Re: 1.9tdi problems
Just on the tach. Dont have access to vcds at this timeAshveer03 wrote:U see that as crank or cam rpm?
The Ride:
- stig
Re: 1.9tdi problems
Replaced cam position sensor using guide on the forum made by another member. Might just be placebo affect but car seems to idle smoother and have not had the long crank since.
Next item for replacement would be the ignition barrel or assembly as it is very hard to get my steering wheel to unlock when car has stood in the sun. Scared I'm going to break the only key I have
The Ride:
Re: 1.9tdi problems
Excellent.
