1.9 tdi loosing coolant
hi guys my 09 jetta tdi 1.9 bxe looses coolant till just under sensor in water bottle (+-1.2l) in about 150km any thing to look out for? Otherwise car runs fine
- aristo92
- Membership No: 3133
Re: 1.9 tdi loosing coolant
Hi bud, first thing would be to check for any leaks in your coolant system. Check all of your coolant pipes for leaks, a puddle of water under the car would be a dead giveaway. If its not that it could be your headgasket on its way as coolant loss is one of symptoms.
- Car Model: Polo Tdi
Check the block on cambelt side from underneath.to see if water pump is leaking...also inspect the water bottle itself...it leaks at the seams
- Car Model: Mk5 gti
Check ur heater radiator not sure if that's what they call it ...its in the dash board my 1.9 tdi done the same thing
viewtopic.php?f=11&t=217296
Previous :too many to list
Inhave never even looked at one of those so don't know it it has but if there is an egr cooler start by bypassing the water supply to that and see if it stops using water.
when mine lost coolant it was the hose running to around there the tandem pump is, it was swollen, i had a small diesel leak from the fuel temp sensor when i bought the car and it rotted that pipe.
had to order form agents
https://www.google.co.za/search?source= ... =038121473
there is also a housing at the back that can leak (audi is at the back longitudinal mounted)
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
