Boost pipes keep slipping off
- casperjjordaan
- Car Model: Polo 9N TDI ASZ (96KW)
Hi guys.
I am having a problem with my boost piping. On my 1.9TDI ASZ 9N polo, I use stock inter cooler, but the piping has been changed to stainless pipes and silicone bends. Now, under on the inter cooler, the god-forsaken 90deg silicone bend keeps slipping of the inter cooler. Resulting in......no boost! I used proper boost clamps, but it does not hold the silicon bend on the inter cooler. Please help me! There is no money for FMI and all of that jazz. I need to fix this.
Here is me Sunday evening at 10pm stuck on the N1 at Rigel. Slipped off boost pipe, yet AGAIN!!
Casper Jordaan
www.accustoms.co.za
Current: 2005 Polo 9N 1.9 TDI (Oo oO) 96KW
Current: 2000 Mazda Rustler 160i (Immaculate!)
Current: 2013 Honda Brio
Ex: 2004 Honda CIVIC 170i VTEC
www.accustoms.co.za
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Re: Boost pipes keep slipping off
Genkem contact adhesive, and clamps need to be f0kken tight
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- M@rk
- Car Model: 1.9 Tdi Sportline
- Membership No: 1776
Hi Casper
Jy moet n lip laat flare op die boostpype , of makliker weld n ridge om die stainless steel boost pype en dan behoort hy nie af te kom nie , en ek hoop jy gebruik T bolt clamps.
Het al 2.7 bar geboost en hule kom nie af nie.
try get some grooves on the stainless pipes so the silicone can grip, apply thin coat of sunlight liquid it will help slip the pipe on when just applied and when hot it gets sticky.
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
- casperjjordaan
Thanks guys. Where the silicone hose goes over the stainless it is sorted out now. I used double boost clamps on every joint. My problem now is mainly where the silicone hose goes over the intercooler. And yes, the intercooler is plastic, so in cannot be clamped like hell-o-va tight. and the fooken thing keeps coming off! HELP ME PLEASE!!
Casper Jordaan
www.accustoms.co.za
www.accustoms.co.za
- BIGMIG
- Porra Love
- Membership No: 1574
Can you share a pic of the inter cooler?
My fix is to
1: Make sure that the hard pipe (metal) has a bead on the end where the silicone pipe will fit over.
2: Lightly run a rasp over the outer wall where the metal meets the silicone. Don't run the rasp over the bead but rather after it, in the same place where the boost clamp will tighten. This creates tiny rough spots for the silicon to bite into.
3: Clean all oil off of pipes and apply light coating of hair spray where the pipe will join. (I have had success with the first two steps and so have never had to use this step.
4: Use worm gear clamps preferably Norma as they have an extra springy band that helps to stop the clamp from loosening itself and creates a better uniform sealing ring. These clamps can usually take about 7nm of torque which is sufficient. There is no need to double up clamps. If however a clamp is stripped then a new one should be used.
My fix is to
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Are you using the right size of silicone bend?
The stock intercooler is 60mm iirc. If its a 63mm bend you will have issues. Also why do you upgraded pipes and stock intercooler?
- casperjjordaan
I bought the car with the newer piping in. Have no idea why they upgraded the piping. The 90deg bend that comes out of the intercooler had a hole in it, so I had to replace the bend, but a OE 90deg bend from VW is R3 960 ex vat. I refuse to pay that. And yes, I took the intercooler with me when I bought the hose.
Casper Jordaan
www.accustoms.co.za
www.accustoms.co.za
- Donavan
on the plastic pipes of the cooler you can use Q-Bond to make a ridge around the pipe
Audi A4 B8 2.0T - Daily
- xXx
- Car Model: MK1 20V T
Hair spray works as well.
Current : 2018 Mark 6 Polo GTI
Ex: : 1994 Citi 1.8T 20 v
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Polo GTI 1.4 TSI ( Biggest kak ever )
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex 2008 Rox 16V ABF ( Miss that car )
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
Ex : Fiesta ST 200
Ex: Polo vivo GTS
Ex : Gti 6 DSG
Ex : R32
Ex : Gti 5 Manual
Ex : Gti 4
Ex : VR6 Jetta
Ex : VR6 Golf
Ex : Golf Cti
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Can I ask a stupid question?
I am going to anyway...
Why run this setup? Are you running extreme boost? If you are then get a proper front mount...
But since you are probably not, why don't you just revert back to an OEM setup? Sure you probably don't have the original piping but get them from a scrappy...
I have never in 14 years had a boost pipe pop off and blah blah blah, the turbo on my car boost properly and I use it everyday...
Again if you plan to upgrade in the future get a front mount and clamp it on there with the force of a pregnant Taurotragus Oryx!!
