k line wire no voltage on
- Kingshill1@
hey guys
have k line wire its got no voltage ecu still fine but unstalling now 95kw turbo into my 74kw but i cant re flash the ecu now through obd2 so benchflash is only option i pressume? is there way to fix that k line wire or trace it to ecu? is there no cheaper option as to pay 2500 for bench flash is there any cheaper person that can assist me with this in cape town area. can i relay the the k wire to be able to read ecu through ob2 again? any advise maybe to get this done.
Vw Polo 1.9tdi
stage 2 map wulfchiptechnic
63mm streight pipe
63mm downpipe
front mounted intercooler
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Re: k line wire no voltage on
According to the info I have, there's no reported signal on the k line.
Pin 7 on the DLC connector goes to pin 16 on the ecu. Grey/white wire..
If I'm not mistaken on the DLC connector:
* pin 4 is chassis ground
* pin 5 is signal ground
* pin 6 is can high
* pin 7 is k line
* pin 14 is can low
* pin 16 is 12v battery power
If u got continuity from the DLC to the ecu plug, and if u got power and ground, a scan tool should communicate with the ecu unless there's a short in a sensor or the ecu.
I'm guessing u have a no communication error?
* pin 6 is can high
* pin 7 is k line
* pin 14 is can low
Contact Johan (Sr Tuned cpt) +27 82 446 3059 he might be able to help u
- Kingshill1@
hey thanks man
yes there is no communication to diagnostic device " no communication to ecu"
all happened after crank sensor gave problem car didnt wane start and then starts and then died on me one day and then replaced crank sensor new one and all engine light and problems gone away untill i wanted to read the ecu and yeah no communication.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
thanks man will hive him a call as to pay 2500 again for this is insaneAshveer03 wrote:Contact Johan (Sr Tuned cpt) +27 82 446 3059 he might be able to help u
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
OK I believe Johan is out of town for now, u can contact this guy instead +27 84 653 2053.
Unfortunately, u probably gonna have to pay a full price to get it tuned. Ur current tuner should be able to do it cheaper since u already their customer..
But hey give this guy a call and check what he says, their after service is good and their files are awesome (power wise and consumption wise), would recommend SR any day. U can see my build thread for a better review haha
- Kingshill1@
thanks buddy no i believe you. i will contact him. i just want to be able to sort out the ecu problem first before do the new turbo install so that i can get it tuned again.
wulfchip is asking me 2500 bench tune it and thats basicly full tune again price anyway. but if this guy can sort me out and get to read my ecu in my car thru ob2 then i will be taking that rather.
will give him a shout. and see prices hes asking also
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Cool, all the best with ur build
- Kingshill1@
thanks man appreciate.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
ok just need to say another thing that day car didnt read was when i braked very hard and abs light with engine light came on and then car didnt wanr start after that. we went thru all sensors and crank sensor was shitting down engine soon touch it so replaced it and car was finr engine light stayed on and then dissapeared with the abs light but i have been reading up and seems my abs can also block out readings to my ecu so im gone tey to disconnect abs sensor and module and see if i can then read ecu ( other engine parts) hope this is this then atleast pinpointed the problem.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Yeah try that
- amstel18
- Car Model: Tiguan Allspace
Might be unrelated.
But I knew a guy that had a highline TDI that was mapped by wulf, and i also couldn't connect VCDS or any other OBD scan tool.
They all worked on my Cupra, but none would connect on his car.
I thought back then, they put some kind of block on the ECU which doesn't allow anyone else to connect.
Have you taken your car back to wulf and can they access the ecu via the OBD port?
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
- Kingshill1@
yeah the problem is that even with the software on before i could still read the car without problems and just after the incidant then i couldnt. so dont think its that. but well worth shot.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
ok tested with abs plug out and still no ecu communication grrrr... really damn hoped that would be the problem. so this means wiring is screwed somewhere problably between the cluster and the obd 2. well i gues its the long route now paying the big ammounts.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
well update i was starting to look undwr dash and found somethinf tjats been cut maybe old wires and then started to trace it and f... there it is damn grey and white k line been cut but heres the funny there is 5 grey and white wires going the other way and one toward obd2 port how the hell do i know which one now.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
all sorted out now connected all the wires together and whalala ecu have lifted off and communication.
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Well done bud
- Kingshill1@
thanks man only thing is see getting 11v between 4 and 7 so which is strange going to disconnect today radio pin 3 to see voltage drops down below 9v. strange is i am reading ecu fine
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
- Kingshill1@
nevermind i read there is 1v difference between battery voltage and k line voltage when ignition on. so all goodKingshill1@ wrote:thanks man only thing is see getting 11v between 4 and 7 so which is strange going to disconnect today radio pin 3 to see voltage drops down below 9v. strange is i am reading ecu fine
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
Vw Polo 1.9tdi
63mm streight pipe
63mm downpipe
