mk4 Turbo refurbish time
- Cass
- Car Model: Mk4 tdi
Hi Friends .
Looking for some information.
My mk4 now has 310 000 , and im looking at having the turbo looked at/ refurbished/replaced.
What are my options here?
1. Remove , decarbon , and re core?
2. replace with 96kw turbo from polo (goldwagen/vw dealership)
3. look for factory stock turbo(vw dealirship).
Im not looking to make mad power , just a reliable daily.
What would be my best route here , and at what price?
current: vw Golf mk4
1.9 Tdi
1.9 Tdi
- Car Model: Sportline
- Membership No: 3194
Re: mk4 Turbo refurbish time
Speak to Gabby at Fastec Turbo.
Well it depends what core u want to use, dont waste ur time with chinese cores. And even with a new branded core, its always a good idea to get it balanced again..
If u have a kp39 (74kw) on ur car at the moment, fitting a bv39 (96kw) turbo will cost quite abit. Need a remap and boost pipe adjustment. +- 12k with a brand new original turbo. U might even need a new oil feed or drain line.
If u not in for the performance then i agree with billionairebum, send the turbo to gaby at fastec for a recon. I highly doubt u get any better than Fastec.
Cass,
Did the original turbo last all the way to 310.000 km? That's very impressive in my books. Are you getting overboost and/or limp mode because of a sticky VNT mechanism?
I'm asking because I also need to exchange/overhaul my AHF's turbo. It's the original one, but was overhauled at 120k, and has now run another 120k. I have a new one (bought from Goldwagen when they had a special in March), but haven't fitted it yet. I'm planning on fitting the new one, then deciding what to do with the old one. Please keep this thread updated!
- Cass
Hi Friends
Sorry for the late reply. yes , my car has the original turbo still fitted, although i do not suffer from limp mode , i do suffer some turbo boost lag. im sure the vnt does not close all the way(sticky) , and the intake is probly clogged aswell. the car is ahf (81 kw) , i think the polo unit is direct swap.
Vagvan , what did you pay for the turbo?
1.9 Tdi
1.9 Tdi
- Cass
could some kind folk help with a part nr for 96kw polo turbo? , trying to see what the lot is going to cost me
1.9 Tdi
1.9 Tdi
Hi Cass,
To my knowledge, the polo unit is a direct swap, provided you fit a new boost pipe on the outlet (intercooler) side. The original AHF turbo has old-style boost pipe fittings (with a normal hose clamp), while the Polo unit, I think, has the "quick-fit" connector (not sure what they are called). The one that just pushes in, with an O-ring and a spring clip to hold it in place.
I bought the AHF turbo (made by Garrett, UK) in March. Can't remember the exact price, but give or take a few 100, it was marked down from about R10.5k to about R7.5k, so I jumped at the opportunity.
- Cass
Thank you very much , im busy investigating a few options
1.9 Tdi
1.9 Tdi
038 253 056H is the 96kw sportline turbo.. costs abt 8k at vw, pretty much the same price at gw..
- Cass
Thats a Moersse help , thank you
1.9 Tdi
1.9 Tdi
I do not think that it is a direct swop.
- Cass
have you tried bilionare?
1.9 Tdi
1.9 Tdi
- Cass
so I got a quote from local guys here in centurion.
Refurbished turbo, including labour fitment etc , incl flushing of hoses and intercooler for 7k ex vat.
Is that a reasonable rate , seeing that GW turbos go for about 10k??
1.9 Tdi
1.9 Tdi
Theres no need to flush the piping and cooler if the turbo didnt explode..
The pipes can be wiped clean, the cooler can be flushed if u like.
I still suggest u send the turbo to fastec. They use original stuff, and the turbos are well balanced and set.
I would be wary of others just changing out the chra with a chinese 1 - thats not a good idea
- Cass
Thanks all for your input. I apologise it has been awhile since i last updated.
So i used some lique Moly intake cleaner , sprayed to the manifold while the car is running to try and chemically clean the egr and intake a bit to see if it will aid in getting rid of some of the boost lag. The car run like normal for a month , but the lag now has returned. So I accept that the vnt is a bit clogged up or sticky atleast.
Has anybody dealt with a company called " Turbo Works" in hennopspark in centurion?
Their customer response and feedback was good and I cant find any immediate bad reviews for them online, and i am willing to give them a shot?
1.9 Tdi
1.9 Tdi
I wonder what "refurbishment" at R7k actually entails... If it were me, I'd enquire about the work they actually do, which parts they use, etc. [Edit: including warranty terms.]
Also keep in mind, Panic Mechanic (Stephan) is just a 20-30 minutes drive from Pta East, out on Delmas Rd., into Benoni outskirts. You could always take your AHF there for a proper diagnosis and some advice.
Turbo direct was running specials last week. Check with them. They were selling OE brand new turbos for under R4k.
- Aslam_mk4
- SO FLUFFY, WE ALL GONNA DIE!
- Membership No: 1824
Cass wrote: ↑Fri Oct 19, 2018 7:54 am Thanks all for your input. I apologise it has been awhile since i last updated.
You can try Tazo at Revo in zwartkops to do a rebuild as well
Speak to Shaun MOOloo
Bagged mk4 2dr
"Ride or die"
"Ride or die"
- Cass
Great thanks for the referance ,I work close to swartkops anyway
1.9 Tdi
1.9 Tdi
again. Check the turbo direct facebook page. They were selling them for under R4K . Why would you do a recon if you can buy a new one. worth a look at the part numbers and see if it is one of the ones they have on special.
- Cass
ok so I managed to get a Nice mahle turbo for my cab , with the gaskets...any pitfalls to look out for during the fitting process? would like to avoid schoolfees where possible
1.9 Tdi
1.9 Tdi
