Hi,
I do have a 2015 2.0TDI Jetta and its due for its 105,000km service.
My service plan stopped at 90,000km.
VW never changed the cam belt as the new service schedule indicates change on 120,000km, but they do recommend changing it on 90,000km (on the customers account of cause )
I've been quote the following part:
1. FILTER (02E 308 051C) - Can buy this from Goldwagen?
2. CAM BELT KIT (03L 198 119F) - Expensive, but I will buy from VW
3. GEAR OIL (G 052 182A2) - Can buy this from Goldwagen? What oil spec is required? DSG
4. ENG. OIL (G 052 195M2) - Can buy this from Goldwagen? What oil spec is required? TDI
5. FOLTERELEM (03L 115 562) - Can buy this from Goldwagen?
Did I miss anything?
Do I need a VAG cable to set/reset the DSG/engine after servicing?
Any special tools for the cambel change.
I do have ElsaWin, but only unt to 2013.....
2.0TDI service advise
- vandyh
- Car Model: Velociti
Current ride
2007 - Jetta VI 2.0TDI
2007 - Velociti - 2.0 (91wkW, 174nm) @ 8V Performance
2014 - Kia Rio TEC
Previous rides
2008 - Polo 1.9 TDi 14i
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
2014 - Kia Rio TEC
Previous rides
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
- Moderator
- Registered for: 19 years 6 months
- Car Model: MK7.5 GTD
- Membership No: 695
Re: 2.0TDI service advise
Hi
I had a 2013 Golf 7 2.0 TDI Highline.
I used everything from GW
The cam belt kit with roller from Goldwagen is a very high quality. It's not worth the extra cost through the dealer.
Tools need for the servies is the timing tool lock kit to lock the crank shaft high, pressure pump and cam shaft.
DSG Oil you can get if from GW Delray Motel DTC it's about R160.00 a Liter. You will need about 6l for the box.
DSG oil can be drained by using the measure system. Drain check how much came out and refill with the same amount through the oil filter housing.
Otherwise you need the filler tool, to fill the DSG box through the drain hole.
Engine needs to be 504/507 spec. Motel and Castrol have this spec. Speak to Wikus at GW Delray
Oil filter and diesel filter GW can supply.
Vag com is needed to reset the next service.
If you use the DSG oil filler tool you willl need the vag com the check the box temp to check the correct oil level through the drain plug.
You will also need a new engine sump plug and DSG drain plug washer.
You tube has a lot of helpfully videos
Build your car for yourself, not what an internet forum tells you.
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
http://www.vwclub.co.za/forum/viewtopic ... 11&t=60525
My Ex Rides
1981 1.3 Escort sold
1988 1.6 VW Fox sold
1995 Jetta 3 CLI sold
1997 Vr6 Hi-jacked
2000 2.0L MK4 Golf sold
2003 1.4 TDI Highline sold
2006 Polo 1.9 S/L sold
1994 CTI 8v Turbo retired
2010 1.6 TDI Sold
2011 Polo 6RGTISold
2013 MK7 2.0L TDI DSG Sold
Current rides
2018 MK7.5 GTD
1992 Fox 2.0 20vt
My Ex Rides
1997 Vr6 Hi-jacked
2010 1.6 TDI Sold
2011 Polo 6RGTISold
Which DSG box is that. If dry clutch then no need for the oil change?. See your installation equipment list in the owners manual.
Or if it is a 7 speed box it is most likely dry cluth. Does not need an oil service like wet clutch boxes did.
- vandyh
Duck,
Thanks for the info. I'll rather buy OEM cambelt as this does not get changed often....
drain oil through oil filter, does this allows all oil to drain out of the box (mounded? on side, bottom?)
Panic,
This one is wet 6spd, agents changed oil last time
Panic,
Current ride
2014 - Kia Rio TEC
Previous rides
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
2014 - Kia Rio TEC
Previous rides
2008 - Citi 14i
1996 - Citi Chico
2003 - Ford Fiesta
1986 - Golf MK2
