Maintenance Service - Cambelt
- CoalWorld23
- Car Make: SEAT
- Car Model: 07' SEAT IBIZA 1.9 TDi FR
Good Day Gentlemen,
I wish to do a service on my Ibiza FR TDI that includes changing of essential belts and associated pulleys.
So far on the list of parts to get i have:
Cambelt/timing belt
tensioner
roller
water pump
hydraulic lifters
i also wish to change fanbelt.
i am guessing that would include alternator belt pulley?
what else?
your advice would be greatly appreciated!
Cambelt/timing belt
tensioner
roller
water pump
hydraulic lifters
what else?
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Re: Maintenance Service - Cambelt
What milage have you done and do you know the lifters are shot?
There is a tensioner on the serpentine belt as well, might as well replace that at the same time. You will need the "spline" tool to get the alternator pulley off if you or your mechenic does not have that.
Other than that your list looks complete...
- CoalWorld23
- Car Make: SEAT
current mileage is 104500 km.VGTI wrote: ↑Thu Aug 30, 2018 10:24 am What milage have you done and do you know the lifters are shot?
not sure if they are or not i just thought id refresh them since i'm doing the belts n stuff. but if i don''t need to that's money saved
ill be sending it to a mechanic, i don't trust myself with these things
okay so
serpentine belt tensioner
fanbelt
fanbelt pulley
cambelt kit
waterpump
sorted?
- Car Model: Sportline
- Membership No: 3194
Also check your mileage on VCDS.
- CoalWorld23
- Car Make: SEAT
Just to double check. That is all.
- NHB_R
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
i wouldnt change the altenator pulley if its not giving you headaches. Also make sure to use the right oil.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- CoalWorld23
- Car Make: SEAT
There's a squeak that comes from one of the pulleys. not the one at the alternator. the one on the bottom. especially on start up. and then fades away or becomes very feint. thats why i wanted to change and refresh everything.MarshallGTi wrote: ↑Thu Aug 30, 2018 12:53 pm i wouldnt change the altenator pulley if its not giving you headaches. Also make sure to use the right oil.
Please advise as to what this may be. Car runs perfectly fine. Just the noise
Mine did that exact squeak thing and eventually the alternator pulley climbed off. The pulley is just a oneway bearing, they eventually seize up.CoalWorld23 wrote: ↑Thu Aug 30, 2018 1:10 pmThere's a squeak that comes from one of the pulleys. not the one at the alternator. the one on the bottom. especially on start up. and then fades away or becomes very feint. thats why i wanted to change and refresh everything.MarshallGTi wrote: ↑Thu Aug 30, 2018 12:53 pm i wouldnt change the altenator pulley if its not giving you headaches. Also make sure to use the right oil.
- MarshallGTi
- Car Make: Seat
If its on the bottom thats the pulley on the aircon comp. Not many places can swap that out, most will just put in a new comp and thats expensive.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- CoalWorld23
- Car Make: SEAT
ill see what i can get changed out as he car has a mechanical warranty on it
The serpentine belt tensioner pulley is normally the cause of the squeak 8/10 times.
The alternator clutch pulley be kind of tested. Also when they faulty, the tensioner jumps around like its gonna explode.
The cam and lifters can be inspected. The lifters are abit difficult to see though.
With the cam kit, u need:
camshaft bearings,
front cam seal,
rocker arm bolts x 8,
cam cap bolts x 10,
and probably a tappet cover gasket.
camshaft bearings,
front cam seal,
cam cap bolts x 10,
