YHELP! WHAT IS THIS CALLED AND WHERE DO I GET ONE?
While driving my whole gearbox dissapeared, or so i thought,what happened was that after pulling away at the traffic light i could not select any gears. Mech said its the clutch, 8K LATER STILL NO GEARS.
i then found a bracket atop the shift tower with a hole that goes onto a shaft and the 2 cable linkages connects to this bracket moving the shaft up and down when selecting gears. This Bracket is stripped. And swings around on the shift tower shaft thingy. What is this bracket called and where can i get this?
For a 2004Polo tdi 1.9... 5 speed gearbox
Re: YHELP! WHAT IS THIS CALLED AND WHERE DO I GET ONE?
Leorall3933 wrote: ↑Fri Aug 24, 2018 9:26 am While driving my whole gearbox dissapeared, or so i thought,what happened was that after pulling away at the traffic light i could not select any gears. Mech said its the clutch, 8K LATER STILL NO GEARS.
Pretty useles without pictures and I also suggest you change your mechanic.
I dont know how to upload the photos. I would like to.
1
1
- Car Make: SEAT
This? (Not where the finger is pointing, but on top of the gearbox)
- Membership No: 2033
Mech seems to be retarded?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Yees. There on top of the gearbox where that black plastic linkage end with the spring is connected to.
Its.
Looks like a cast iron bracket that has that 1 nut in the middle
Its.
- Car Make: SEAT
Doubt whether you'll get that separate from the gearbox at the stealers, but you could try a scrappie/gearbox recon place?Leorall3933 wrote: ↑Fri Aug 24, 2018 12:26 pm Yees. There on top of the gearbox where that black plastic linkage end with the spring is connected to.
Its.
City used spares said they do get them in but dont have stock currently. Might get some in on tuesday they sell them for R350. Maaaaaar hatfield vw said they can order a new one for me at 776 bucks.
Also if anyone in the future have some trouble its called a few names..
(Gear selecter/link gear/cable bracket) part nr is 6Q0 711051.
- Car Make: Ford
- Car Model: FiST
You probably already got one, but if you haven't, perhaps try Majestic Auto Parts
Hey man. Thank you. I got a new upgraded version one from vw hatfield at half the price the scrappies asked me.
R776.
Just finnished installing it. Shes like a dream again.
Thanks for all the replies!
R776.
