Hi i recently changed the motor on my crewbus now it starts but when the ignition is turned off it only starts in third attempt.. diagnostic says cam positioning senor checked it still the same
Sent from my SM-G955F using Tapatalk
T5 2.0tdi starting problems
- Registered for: 7 years
Re: T5 2.0tdi starting problems
did you check the engine speed sensor
Yes we replaced it
what is the exact fault. If is says cam correlation error it means the timing is out which will make hard start.
Sent the van to Vw for 150k service an requested the timing belt be changed....so they set timing an they could also not fix the problem... to me it's as if its a fuel related problempanic-mechanic wrote:what is the exact fault. If is says cam correlation error it means the timing is out which will make hard start.
Are u still getting the cam related fault code? If so, post the entire code here.
Just because it had been done by a dealer, doesnt mean its 100%. Some dealers dont know what they doing
