Looking for some info as this is my 1st time owning a diesel. I bought a 2004 2door polo 1.9tdi with 190000km on the clock.
I would like to know the following.
1.What are the service intervals on these cars?
2.which oil do I use?
3.is there any other maintenance that needs to be done on these cars at this age?
4. Do I need to remove the cat? Is there any benefit to it?
5. Wheel bearings on these cars what do they cost as I need to get them done.
6. Ecu remap who is the best in Cape Town? And what type of figures can I expect? Is it worth doing the remap?
Thanks in advance guys!
New polo tdi owner
Re: New polo tdi owner
1.What are the service intervals on these cars? Do it at 10k kms
505.01, i prefer liqui moly toptec 4100. Others use shell hx7 av. Choose 1 and stick with it.
Check when the cambelt was done.. dont fix what's not broken rather fix when problems show themself. U can look for and repair any boost leaks though..
Common stuff, control arm bushes are weak, camshafts get eaten..
U dont have to but its not a bad idea. If the cat is kinda blocked then u will see a slight performance gain and more exhaust noises.
Cant remember but around 300-400 each.
SR Tuned
And what type of figures can I expect? Well that depends
Is it worth doing the remap? Yeah, SR files really give good consumption when cruising and nice power when u floor it.
SR Tuned
- Car Model: Sportline
- Membership No: 3194
1.What are the service intervals on these cars? 7500km oil service, 15000km full service
2.which oil do I use? LM Toptec 4100, Motul X-clean 8100, Something 505.01 spec
3.is there any other maintenance that needs to be done on these cars at this age? As above what Ashveer said + check lifters and cam.
4. Do I need to remove the cat? Is there any benefit to it? Yes
5. Wheel bearings on these cars what do they cost as I need to get them done. As above
6. Ecu remap who is the best in Cape Town? And what type of figures can I expect? Is it worth doing the remap? First get your car 100% then look at software. Software wise will always be a debate so do your research and find someone you trust. RK motion...
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
Some people prefer to get OEM wheel bearings and they are expensive. Getting cheap ones could give ABS/ESP issues.
Are you sure the bearings are bad? My car is on 360000km with the original wheel bearings, I replaced one but the noise was caused by the tyres. What tyres are fitted to your car?
Yeah bearings dont go very often on a polo..
Goldwagen bearings work without issues, i think they are WAG bearings, fitted a good few no problems at all..
- Unobeat
- Car Model: Uno, Auris, CX-5
OFF TopicVGTI wrote: ↑Fri Aug 17, 2018 11:21 am Some people prefer to get OEM wheel bearings and they are expensive. Getting cheap ones could give ABS/ESP issues.
Good to see this car is aging well and still going strong.
Thumbs up VGTI for taking care of it.
Hey I am assuming.everyone that drove in the car this far said it’s the bearings. I will go to a suspension shop and do some further investigationVGTI wrote: ↑Fri Aug 17, 2018 11:21 am Some people prefer to get OEM wheel bearings and they are expensive. Getting cheap ones could give ABS/ESP issues.
Thanks guys so I don’t drive much I probably do about 600 to 800km a month. Belt was changed 3months ago.
