Finding boost leak on a TDI
- MarshallGTi
- Registered for: 13 years
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Any tips from the old pro's like Panic? I don't have a compressor at home so can't use a normal tester, and for the life of me i can't find any spots that might be leaking, checked and replaced hoses, seals and clamps etc. It's driving me nuts.
kthxbye
kthxbye
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
- Car Model: Sportline
- Membership No: 3194
Re: Finding boost leak on a TDI
Your connection to the turbo. Check it and check that pipe. Look for oil.
- MarshallGTi
- Car Make: Seat
Done, new o-ring, new silicone bend cut a bit shorter than the last so it definitely wont touch the droplink, and new clamps for good measure lol
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Spray soapy water on the piping, start car look for bubbles? This may not show a tiny leak though..
Can u hear the leak? Or the car is boosting less than it suppose to?
If u have been driving around with the leak for a while it should have shown itself by now..
Another spot is the map sensor flange..
- MarshallGTi
- Car Make: Seat
Cant hear it but holds peak boost fine til about 3200rpm and then loses 0.5bar from 3200 to 4500.
No evidence i can see of oil seeping through a pipe of anything, and no soot around the turbo either.
new o-ring and MAP sensor and filed the flange flat and smooth.
Will try soap and water, also have a tin of quickstart spray lying around to try while its under vacuum.
Just gatvol of trying and looking and not finding fokol.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Stupid question but is the ECU Map still requesting peak boost all the way to 4500?
This needs to be checked, run a log of grp11 and see if the requested matches actual.. generally boost does taper down as rpm climbs..billionairebum wrote:Stupid question but is the ECU Map still requesting peak boost all the way to 4500?
Most stock turbo pd130s i have seen hold 1.6bar (tuned) at around 3500rpm and then taper down to around 1.2-1.3bar at popcorn
^^^Ashveer03 wrote: ↑Fri Aug 17, 2018 1:28 pmThis needs to be checked, run a log of grp11 and see if the requested matches actual.. generally boost does taper down as rpm climbs..billionairebum wrote:Stupid question but is the ECU Map still requesting peak boost all the way to 4500?
Not a stupid question after all, marshall might be chasing a problem that doesnt exist lol
- MarshallGTi
- Car Make: Seat
Tyrones done my logs when we tried loading a stage 2 map, but thats a good thought will see if we can make a plan and recheck after the recent changes.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
No whining from the turbo by any chance?
- MarshallGTi
- Car Make: Seat
Brand new turbo in January, still perfect condition.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ok cool i guess a log will tell whats going on
- Valcon
- Wheel Whore
- Car Model: Crosspolo
- Membership No: 3243
Just as a check i would find a friend with a compressor and do the leak test anyway, its good to double check all your fittings once in a while.
2009 VW Crosspolo 1.9tdi with Qtec stage one remap.
2015 VW Polo 1.2Tsi ( The Wifes Car)
1989 VW Golf MKll GTi - Engine swapped to a 2.0L 8v long block with dickator management - SOLD
1993 VW Golf MKlll GTi - SOLD
I really doubt a stock turbo would / should hold the full 1.6 after 3500 rpm.
