I need some help and expertise to diagnose vehicle in subject that cranks but does not start. This vehicle has about 302 000km on the odometer and relatively trouble free for the last 150 000km. Serviced only at the dealer except for cambelt changes which I do myself and one or two instances where I had intermittent faults which the dealer was not able to fix within the scheduled service window.
The current problem I have is that the engine cranks but fails to start. The car died whilst driving with Glowplug Light coming on and the MFD displaying Engine Fault - Workshop. I was not able to restart it. At that point I was relatively low on fuel - eventhough I have driven with a much lower fuel level without issues in 285 000km I have owned the vehicle. At the time I only owned a basic OBD scanner and found only a single DTC which indicated 'Fuel Rail Pressure Low' - I accepted defeat and put this down to too low fuel level. I filled the tank, then primed both the in-tank and engine bay electric fuel pumps as per tutorial for the diesel filter change however, still only cranking and no starting. I then proceeded to bleed the HP fuel system between the HPFP and Injectors and managed to get the engine started. I left the engine to idle for a fair amount of time whereafter I decided to take the vehicle back home which is about 5 to 10km trip. On the way home I noted that the fuel guage was now not working and assumed that the electrical plug on the fuel tank pump unit was not in properly - a few kilometres into the journey the glowplug light appeared again, and the same engine fault - workshop warning appeared in the MFD, however, it did not cut out and only went into limp mode - which allowed me to get back home however, cut out just as I parked it in front of the garage. This time I assumed it must have been as a result of the electrical socket not completely inserted on the intank fuel pump. I then proceeded to prime pumps again (the hard way without VCDS) and prime the HP fuel system, however, have not been able to get it started again - now this is where I need help!
In order to diagnose the reason for cranking and not starting I have done the following:
1. Order VCDS,
2. Opened up diesel filter canister - inspected for any debris, alum filings etc. None found and also replaced filter even though it is only due for replacement in another 15000km.
3. Pulled the in tank fuel pump and inspect for any debris or blockages etc - some debris on screen but I guess it can be expected for a 300 000km vehicle.
I have now received my VCDS software and have worked through the basics of the software in order to use it. I have scanned for new DTC's and no new DTC's showed.
Any ideas where to start looking? I have looked at some basic items in VCDS such as the rpm's and fuel rail pressure during cranking. Crank rpm is between 200 and 300 rpm and fuel rail pressure around 240bar. Are these values high enough to release fuel injection? Can I check in VCDS if fuel is injected and is there perhaps some other parameters that might not be met that prevents injection and/or need to be reset?
Any help would be appreciated!
Thanks,
Code: Select all
Wednesday,25,July,2018,09:27:09:01273
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 18.2.1.5 (x64) HEX-V2 CB: 0.4411.4
Data version: 20180518 DS287.2
www.Ross-Tech.com
VIN: WVWZZZ1KZAW006014 License Plate:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZAW006014 Mileage: 301360km-187256miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 LA HW: 03L 906 022 G
Component: R4 2,0L EDC G000SG 3893
Revision: 13H02--- Serial number:
Coding: 0001072
Shop #: WSC 01357 011 00200
VCID: 6FBA25881B9D43EF98E-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 163B400D09220000680B02E5901D00823000
VCID: 7EA408CC40F73A67038-802A
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 1
Fault Frequency: 1
Reset counter: 200
Mileage: 301369 km
Time Indication: 0
Date: 2012.12.13
Time: 00:00:58
Freeze Frame:
Count: 16391
Count: 3
Count: 4096
Count: 128
Count: 41216
Count: 0
Count: 0
Count: 3328
Address 08: Auto HVAC (J301) Labels:| 3C8-907-336.clb
Part No SW: 3C8 907 336 J HW: 3C8 907 336 J
Component: Climatic H13 0203
Revision: 00006001
Coding: 0000000000
ASAM Dataset: EV_Climatic A01001
ROD: EV_ClimaBasis_VW36.rod
VCID: 3430EAE43EBB2037A5C-8060
2 Faults Found:
9477489 - Motor for Air Distribution Flap
B109D 71 [008] - Actuator stuck
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 5
Reset counter: 233
Mileage: 301212 km
Date: 2018.07.04
Time: 10:32:55
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
[Motorsteuergerät - bitte Fehlerspeicher auslesen]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 300378 km
Date: 2018.06.16
Time: 05:44:28
Address 09: Cent. Elect. (J519) Labels:. 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 C HW: 1K0 937 086 C
Component: BCM PQ35 M 103 0537
Revision: 00103 AB
Coding: 4E180A3E9025F1C044080080140081E441510088536D8560648000200000
VCID: 3038E6F4CA231C17C14-8064
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 29040 21 0501
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 150509 05 54 0402
Coding: 0330AD
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K0 951 605 D
Component: LIN BACKUP HO H08 9001
8 Faults Found:
02395 - Parking Light Front Right (M3)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 2
Fault Frequency: 18
Reset counter: 240
Mileage: 296384 km
Time Indication: 0
Date: 2012.08.14
Time: 08:56:20
Freeze Frame:
Term 15 Off
Voltage: 11.80 V
OFF
ON
Term 50 Off
OFF
OFF
01518 - Bulb for Back-Up Lights; Left (M16)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 98
Reset counter: 225
Mileage: 297990 km
Time Indication: 0
Date: 2012.10.07
Time: 08:27:39
Freeze Frame:
Term 15 On
Voltage: 14.05 V
ON
ON
Term 50 Off
OFF
ON
00984 - Left Tail Light (M4)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 224
Mileage: 300040 km
Time Indication: 0
Date: 2012.11.02
Time: 17:51:11
Freeze Frame:
Term 15 On
Voltage: 13.50 V
ON
ON
Term 50 Off
OFF
OFF
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 239
Mileage: 301339 km
Time Indication: 0
Date: 2012.12.11
Time: 16:56:30
Freeze Frame:
Term 15 On
Voltage: 13.85 V
ON
ON
Term 50 Off
OFF
OFF
00907 - Intervention load Management
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 239
Mileage: 301359 km
Time Indication: 0
Date: 2012.12.12
Time: 10:34:60
Freeze Frame:
Term 15 On
Voltage: 11.30 V
ON
ON
Term 50 Off
OFF
OFF
00834 - Signal for Activation of Heated Rear Window
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 240
Mileage: 301369 km
Time Indication: 0
Freeze Frame:
Term 15 Off
Voltage: 12.20 V
OFF
ON
Term 50 Off
OFF
OFF
03266 - Control Circuit for Signal Horn
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 240
Mileage: 301369 km
Time Indication: 0
Date: 2012.12.13
Time: 02:35:57
Freeze Frame:
Term 15 Off
Voltage: 12.15 V
OFF
ON
Term 50 Off
OFF
OFF
00153 - Windshield Wiper Motor; Driver Side (V216)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 240
Mileage: 301369 km
Time Indication: 0
Date: 2012.12.13
Time: 00:00:02
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 5K0 959 655 HW: 5K0 959 655
Component: AirbagVW10 033 0604
Serial number: 003C2R90774S
Coding: 00003230
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 77AA1DE86F4D0B2F40E-8022
Crash sensor for side airbag: driver side:
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V U01 ----
Serial number: 14656247ZZZZZZZZZZZZ
Crash sensor for side airbag: front passenger side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V U01 ----
Serial number: 7A360448ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 1E1A2766ZZZZZZZZZZZZ
Crash sensor for side airbag: rear: passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 22062752ZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CQ HW: 1K0 953 549 CQ
Component: J0527 053 0111
Coding: 0000034
VCID: 035279382715578F6C6-8056
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 5K0 920 870 E HW: 5K0 920 870 E
Component: KOMBI H05 0206
Serial number: 00000000000000
Coding: 170B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
VCID: 2F3AE588D79D03EFD8E-807A
1 Fault Found:
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 240
Mileage: 301359 km
Date: 2018.07.22
Time: 10:21:30
Address 19: CAN Gateway Labels:. 1K0-907-530-V4.clb
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 110509F2001070
Coding: E9807F06000202000003
VCID: 669440AC346782A7EB8-8032
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
ROD: EV_Immo_UDS_VDD_RM09.rod
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 5K0 959 701 D HW: 5K0 959 701 D
Component: Tuer-SG 009 2124
Coding: 0000692
VCID: 3332E9F83735270FBC6-8066
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 70 2901
Revision: 00H15000
VCID: 2F3AE588DB1D03EFD8E-807A
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Time Indication: 0
Freeze Frame:
Battery Volts: 12.6 V
PD
Temperature: 13.0°C
Count: 2
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 5K0 959 702 D HW: 5K0 959 702 D
Coding: 0000692
VCID: 3430EAE4323B2037A5C-8060
Address 56: Radio (J503) Labels:. 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AA HW: 1K0 035 186 AA
Component: Radio RCD310 013 0036
Revision: 01000000 Serial number: VWZ1Z2I6151234
Coding: 0500040004
VCID: 659647A0C56189BFE22-8030
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 3536D7E03941393F922-8060
End----------(Elapsed Time: 01:06, VBatt start/end: 12.1V/12.1V)-----------
