The car start and idle perfect. When pushing on the accelerator the revs increase slowly. There is no power.
The turbo was replaced and the cat removed. The timing belt was replaced. I checked the timing with proper tools and found to be correct. I check the system and had to replace the MAF sensor. All the vacuum hoses was checked and found to be in order. The vacuum solenoids was checked and found to be in order. The fuel filter was replaced.
I removed the fuel hose on the filter and found that it is difficult to suck the fuel from the tank and if i keep my tongue on the end of the pipe i can feel the suction. if i pull my tongue of the fuel goes back to the tank.
Please note this car is not fitted with electrical pump in tank.
Any advice will be appreciated
1.9 TDI Golf 4 poor performance and slow revving
- Tdi jetta 4 ever
Re: 1.9 TDI Golf 4 poor performance and slow revving
Please explain how you checked the timing ? Did you lock the injector pump and cam in place when you replaced the belt ?
You can disconnect that same fuel hose and blow the diesel back with air while your filler cap is unscrewed then suck and see if its better.
Keep us up to date.
Keep us up to date.
Robin
robinwisse@gmail.com
Did You do a injection timing check with vcds. Does it boost when you drive it.
