Jetta 1.9Tdi 2003
BertPretorius
Registered for: 5 years 9 months
Jetta 1.9Tdi 2003
Post by BertPretorius »
Where can I locate the cam sensor? I have googled all over and can't find any reference to a cam sensor on this particular Tdi's.
My Tdi just cuts out while driving. Then after numerios attempts it starts, revs up, and cuts out again. After plenty attempts it will start only to cut out again in few hundered meters.
Goldwagen is selling cam sensors for these Jettas but I can't locate it on my car.
billionairebum
Registered for: 9 years 2 months
Car Model: Sportline
Membership No: 3194
Re: Jetta 1.9Tdi 2003
Post by billionairebum »
Engine code?
Deranged_9n3
Darth Vader
Car Model: Polo 1.9TDI Sportline
Membership No: 1639
Post by Deranged_9n3 »
billionairebum wrote: Tue Jun 12, 2018 2:31 pm Engine code?
ALH engine code
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
BertPretorius
AHF engine code
Rudi46
Registered for: 14 years 5 months
Car Make: Nike
Car Model: Walk and see more
Post by Rudi46 »
No Cam sensor on the AHF, did you have the car scanned?
Current - 1994 VW Caddy 1.8i
Ex - 83 Caddy
Ex - 02 Audi S3
Ex - 98 Golf Chico 2L
Ex - 01 Golf 4 Tdi
Ex - 92 Citi shuttle 2L
Ex - 90 Yamaha FZR1000
Ex - 90 Honda CBR400
Ex - 03 Honda NSR150SP
BertPretorius
Had a diagnostic done today...errors are code 01314(Engine control module), 00668(Vehicle voltage terminal), P3105(Intake manifold flap valve), P0321(Ign/Distr eng speed range/performance).
What now???
No cam sensor but it does have a timing sensor on injector 3.
Some of those were caused by a flat battery.
Clear them all - take it for drive and see what comes back.
VAG Fan
Registered for: 8 years
Post by VAG Fan »
[Edit: I see Stephan has already responded, but my post was finished anyway, so I'm going to submit it anyway, for what it's worth.]
The engine control module, at least in the Golf 4 TDI - presumably also in the Jetta, is mounted in the middle of the rain tray (as I was rather shocked to find out when I worked on my Golf's wipers). I wonder whether it has some corrosion on a connector, giving rise to a voltage problem (errors 1314 and 668).
The intake flap valve is activated by the ECM to force-stop the engine, e.g. when you shut the engine down with the ignition key. The mechanical default position of the flap valve is open, and the ECU uses a vacuum actuator to close it when required. I wonder whether your ECU is somehow activating the flap - which would obviously lead to the engine cutting out (error P3105).
If it were my car, I would check the connections on the ECM for corrosion, to start with. I'm still pretty new to the AHF, so this is just a shot in the dark, based on some of your error codes.
BertPretorius
Errors were cleared and crank sensor cleaned. Hasn't cut out again although I haven't driven far..only short distances. Will see once I drive a longer distance
