Golf 5 1.9 tdi vibration on clutch pedal
sanelenanti
Registered for: 6 years 1 month
Post by sanelenanti »
I have a 2005 Golf 5 1.9 TDI with 277000 kilometers on the clock. I have noticed that recently when I slightly tap my foot on the clutch pedal or leaving the clutch upon changing gears, I feel vibration on the pedal.
Pointers and suggestions/advices are appreciated.
Re: Golf 5 1.9 tdi vibration on clutch pedal
start of the end of the dual mass flywheel.
sanelenanti
panic-mechanic wrote: Sun May 06, 2018 8:07 pm start of the end of the dual mass flywheel.
Thanks Panic. What is the worst that can happen if it fails completely? Is it also advisable to install a used one or I need a new one?
Anyone who might happen to have this kind of a flywheel?
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
Always replace a DMF with a new one, they are not reuseable. Contact your nearest Goldwagen who will be able to supply a Luk or Sachs kit.
ICE King
Post by ICE King »
sanelenanti wrote: Mon May 07, 2018 7:13 am
Worst case is the flywheels separating on the DMF , - Hole in the bell housing or gearbox
If you have a 5 speed , a SMF combo might be an option but I stand corrected
Personally I would replace with a new DMF and be done with
Ashveer03
Post by Ashveer03 »
Nothing wrong with a smf kit - used quite a few kits on the 6speed polos with no problems at all, very little chatter with a little harder pedal feel though..
U can get a smf kit for around 5-6k from TPH (The Performance House) in the GP area(facebook them)
billionairebum
Car Model: Sportline
Membership No: 3194
Post by billionairebum »
https://www.facebook.com/AdrianOdendaal92/
TDI Performance house. Give Adriaan a call, he has a special running.
sanelenanti
Thanks guys for your inputs.
sanelenanti
Just an update guys, it turned out that it was the DMF, replaced with LUK Clutch kit and problem solved.
