Help with Injector Adaptation / Programming
sambowks
Car Model: Cross Polo 1.6 TDI
Post by sambowks » Sat Mar 10, 2018 5:40 pm
Hi All - I had an injector fail and had a local guy replace it. He was not able to do the required code adaptation to the new injector. Can this be done with one of those VCDS cables on gumtree,r Should I get someone to do it? If there is anyone out there willing to do it please let me know as well.
My no: 072 801 8545
BIGMIG
Porra Love
Car Model: 9N3 GTB22/60vk Sportline
Membership No: 1574
Re: Help with Injector Adaptation / Programming
Post by BIGMIG » Sat Mar 10, 2018 10:34 pm
Was it a straight swop or was the injector reburbished first. Also what injector was used pd100,pd130 or pd160?
My DonkeyPiel assassin
Goose, soot ninja
Ashveer03
Post by Ashveer03 » Sun Mar 11, 2018 5:21 am
What engine are u working with? If its a pd then as far as i know, u dont need any adaptations. But, if u fitted in an injector/s with a different part number then u need adjustments made on the software by a tuner.
sambowks
Post by sambowks » Sun Mar 11, 2018 7:06 am
It's a 1.6TDI that uses piezo injectors made by Siemens/Continental. Each injector has different tolerances and these are reflected by a unique code printed on top of the unit, which needs to be put into the ECU. I have confirmed that these injectors cannot be refurbished, serviced, at least not locally. I have already replaced the injector, but my local mechanic does not have the correct software to enter the code.
https://www.youtube.com/watch?v=syKv2MIUS9o&t=25s
missioner
Car Model: '87 MK1 Golf Citi
Post by missioner » Sun Mar 11, 2018 7:18 pm
sambowks wrote:It's a 1.6TDI that uses piezo injectors made by Siemens/Continental. Each injector has different tolerances and these are reflected by a unique code printed on top of the unit, which needs to be put into the ECU. I have confirmed that these injectors cannot be refurbished, serviced, at least not locally. I have already replaced the injector, but my local mechanic does not have the correct software to enter the code.
VCDS should be able to do it.
Where are you located? If you are in the East Rand give Panic Mechanic a PM and make a booking with him. He's worth every cent.
