1.9 TDI OIL
MSD
1.9 TDI OIL
Post by MSD » Wed Jan 31, 2018 8:44 am
Hi everyone,
Ive read on the forum that the oil spec must meet 505.01 specifications and must be synthetic. The engine is the 74kw ATD motor and this is the first service that needs to be done since i got the car.150 000 km on the clock.
Can i use or
Shell Helix Ultra 5w-30 or
Shell helix Ultra 5w-40 or
Shell helix HX7 5w-30 or
Shell helix HX7 5w-40?
Any idea on how much the cam belt service should cost? and is it necessary to replace the brake fluid?
TD HIGH
Car Make: Honda/Seat
Car Model: Accord 2.4L/ IC 1.9TDI
Re: 1.9 TDI OIL
Post by TD HIGH » Wed Jan 31, 2018 9:18 am
Hi bud
I use liqui moly top tec 4100 and so far it has done me well
Breakfluid i change once a year just because i suppose, also use liqui moly
Cambelt kit GW delarey should be able to sort you out with pricing.
Seat IC 1.9 TDI
stage 2, straight pipe, cupra lip,Depo racing 3 bar boost gauge, - His
Honda accord 2.4l old man car - Hers
Polo TDI
40mm evo drop, gti headlights, fmic, 63mm straight s/s pipe, bmc filter, toxic tuning sw, 132wkw 447 nm sold
98 Citi 60/40 drop custom sound install - RIP
NHB_R
Re: 1.9 TDI OIL
Post by NHB_R » Wed Jan 31, 2018 9:26 am
Re: 1.9 TDI OIL
Post by panic-mechanic » Wed Jan 31, 2018 9:29 am
Ultra not hx7 in the correct viscocity according to your owners manual.
'07 Audi S6 V10 - beast !!!!!
'09 Audi Q5 3l tdi
'95 Audi 90 coupe quattro
4ePikanini
Car Model: Touareg R5
Re: 1.9 TDI OIL
Post by 4ePikanini » Wed Jan 31, 2018 9:36 am
Check the bottle. If it says 505.01 approved then you can use it. If it doesn't, you can't.
My Touareg Build
jimbo
Car Model: MK5 1.9 TDI DSG
Re: 1.9 TDI OIL
Post by jimbo » Wed Jan 31, 2018 9:39 am
When I took my Golf 1.9 TDI to VW earlier this month for an oil change they used Fuchs Titan? - however not sure of it's availablity or how it compares to Shell, Motul etc.
Sent from my LG-H815 using Tapatalk
Neuk
Treasurer
Treasurer
Car Model: '15 Golf R
Membership No: 806
Re: 1.9 TDI OIL
Post by Neuk » Wed Jan 31, 2018 10:24 am
panic-mechanic wrote:Ultra not hx7 in the correct viscocity according to your owners manual.
Why not HX7? It is VW 502.00/505.01 approved but only the 5W-30, the 5W-40 is VW 502 00/505 00 approved.
Nic
Daily Drive: 2015 VW Golf R
MarshallGTi
Car Model: Ibiza 1.9TDi FR
Membership No: 1665
Re: 1.9 TDI OIL
Post by MarshallGTi » Wed Jan 31, 2018 12:49 pm
it has to be HX7 AV if i'm not mistaken, but LiquiMoly 4100 is best.
Cambelt with waterpump and coolant should be R2500 - R3000 these days.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Re: 1.9 TDI OIL
Post by panic-mechanic » Thu Feb 01, 2018 9:18 am
Read the bottle and see what the manual says. Only ultra or hx7 AV has the correct spec. Ultra is actual synth so I Prefer that.
So although I can't fault liqui moly - my touareg takes 13L of this stuff every 10000 km so that means around R2200 for oil per change.
The shell that works just perfectly fine costs me under R1200 for the same oil change. So for me it just ain't worth it.
'09 Audi Q5 3l tdi
ICE King
Re: 1.9 TDI OIL
Post by ICE King » Thu Feb 01, 2018 9:43 am
HX7 is semi-synthetic (half mineral) - for thus reason I would agree with panic for the application.
I recently moved from Ultra to HX8 and found that I no longer have a oil consumption between my 10000km oil changes and it's cheaper so it works for me however Ultra still remains the more superior oil between the two.
Rides:
Dale
Re: 1.9 TDI OIL
Post by Dale » Thu Feb 01, 2018 10:12 am
Shell Rimula R4
VAG Fan
Re: 1.9 TDI OIL
Post by VAG Fan » Thu Feb 01, 2018 10:34 am
ICE King, interesting that you should mention oil consumption between changes. My TDI (VE-110) was always serviced by the previous owner's workshop with VW oil (not sure which one or where VW source their oils), and according to him, never required a top-up between intervals. I put in Shell Ultra 5W40 15000 km ago, and now that the next change is due, it's used more than a litre. I'm not too fazed about it, but I wonder whether there are more volatiles in the Ultra than in other oils.
MarshallGTi
Membership No: 1665
Re: 1.9 TDI OIL
Post by MarshallGTi » Thu Feb 01, 2018 11:07 am
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Re: 1.9 TDI OIL
Post by panic-mechanic » Thu Feb 01, 2018 12:55 pm
Dale wrote:Shell Rimula R4
Definately NOT suitable. It will eat that pd cam in no time at all.
'09 Audi Q5 3l tdi
Re: 1.9 TDI OIL
Post by panic-mechanic » Thu Feb 01, 2018 1:11 pm
VAG Fan wrote:ICE King, interesting that you should mention oil consumption between changes. My TDI (VE-110) was always serviced by the previous owner's workshop with VW oil (not sure which one or where VW source their oils), and according to him, never required a top-up between intervals. I put in Shell Ultra 5W40 15000 km ago, and now that the next change is due, it's used more than a litre. I'm not too fazed about it, but I wonder whether there are more volatiles in the Ultra than in other oils.
Vw ises castrol. Ultra has a much more aggressive detergent package so t is eating away at some stuff thatbhas built up.. The oil consumption will stabilize again. Just keep using it.
'09 Audi Q5 3l tdi
Dale
Re: 1.9 TDI OIL
Post by Dale » Thu Feb 01, 2018 2:51 pm
I have been using this in my car for past two years as well as a couple of mates in their enduro bikes. the 12 second mk1 golfs at tarlton - same oil.
No harm thus far.
Neuk
Treasurer
Treasurer
Membership No: 806
Re: 1.9 TDI OIL
Post by Neuk » Thu Feb 01, 2018 3:07 pm
No harm thus far.
Why do you recommend an oil that doesn't have a single VW rating for use in an engine that requires a very specific VW rating?
Nic
Dale
Re: 1.9 TDI OIL
Post by Dale » Thu Feb 01, 2018 3:53 pm
No harm thus far.
Apologies, forgot the question mark. Does diesel need specific 505.01 oil?
My car is running two years on this no issues.. A friend still running it in his YZ450 60th edition. The viscosity is better in my opinion for JHB heat conditions.
Rimula specs:
API CI-4, CG-4, CF-4, CF; ACEA E7, E5; Global DHD-1, Cummins CES 20071, 72, 76, 77, 78; Cat ECF-1-A; DDC 93K215; Mack EO-M, EO-M+; MAN 3275; MB Approval 228.3; Renault Trucks RLD-2; Volvo VDS-3
Neuk
Treasurer
Treasurer
Membership No: 806
Re: 1.9 TDI OIL
Post by Neuk » Thu Feb 01, 2018 4:14 pm
Dale wrote:
Neuk wrote:
Dale wrote:
panic-mechanic wrote: Definately NOT suitable. It will eat that pd cam in no time at all.
No harm thus far.
Rimula specs:
A PD TDi engine is a diesel but it is certainly no truck engine like most of the Rimula specifications cater for. VW PD TDi engines require VW 505, 505.01 or 507 specification oil which Rimula does not comply with.
Nic
VAG Fan
Re: 1.9 TDI OIL
Post by VAG Fan » Thu Feb 01, 2018 4:47 pm
This makes sense, and I do hope you're right about the consumption stabilising in due course.
Re: 1.9 TDI OIL
Post by panic-mechanic » Thu Feb 01, 2018 8:08 pm
VW Pumpe Duse (PD) engines compresses the diesel injector pump with the cam to around 1600 to 2000 bar. It creates massive shear force between the cam and the injector. There was VERY VERY specific shear properties that an oil has to comply to to be suitable for use in that engine otherwise it will eat the cam like a three year old on a lollipop. That spec is 505.01 or 507 if it has PD and a DPF.
So before flying off and telling us that 12 second petrol engined golfs is ok with it and bikes and truck engines thus by that conclusion it must be ok -
perhaps do some research as to what engine you are actually giving advise for. If somebody think it is a good idea and follow your bad advise there is no recourse for them but it will cost them thousands and thousands to repair.
Here is a link if you want to bother to self educate
https://www.myarchive.us/richc/VW_TDI_w ... peDuse.pdf
'09 Audi Q5 3l tdi
MSD
Re: 1.9 TDI OIL
Post by MSD » Tue Mar 13, 2018 1:49 pm
So i replaced the water pump, cambelt kit, oil level sensor under the sump, oil with shell helix ultra 5w-40, air filter, oil filter and diesel filter. Total R5 000.00 for everything including installation.
The motor does sound lightly louder which im hoping is not a major issue.
Jueshen
Re: 1.9 TDI OIL
Post by Jueshen » Wed Mar 14, 2018 7:29 am
the oil you used is only approved for 502.00 and 505.00
dont you need 505.01?
2003 Audi A4 Avant 1.9TDI
2015 Toyota Corolla D4D
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
MarshallGTi
Membership No: 1665
Re: 1.9 TDI OIL
Post by MarshallGTi » Wed Mar 14, 2018 8:51 am
MSD wrote:So i replaced the water pump, cambelt kit, oil level sensor under the sump, oil with shell helix ultra 5w-40, air filter, oil filter and diesel filter. Total R5 000.00 for everything including installation.
looking for trouble
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
VAG Fan
Re: 1.9 TDI OIL
Post by VAG Fan » Wed Mar 14, 2018 9:45 am
When I started reading up on VW TDI oil specifications, I found this page; towards the end, it contains a flowchart that I found helpful.
https://www.oilspecifications.org/artic ... lained.php
My TDI is an old VE-type, so it has a classic "low-shear" 8V valvetrain, which is why I'm using Shell Ultra 5W40 (specced for 505.00 but not 505.01). If I were driving a PD, I would be looking for a 505.01 spec oil. Interestingly, Helix 7 Professional "AV", even though it is only "synthetic technology", not fully synthetic, satisfies 505.01. It must be the specific additive package. I wonder whether panic-mechanic will chime in when he gets back...
