Oil change.
- Car Model: Jetta 1.4TSI
Oil change.
Hey members all the best for 2018!
Just have a quick question, iv got a 1.9tdi Polo 74kw and its due for a oil change.
What would be the best oil to use? The mileage is just on 150k km.
Also how good is the Liqui Moly range on oils?
- Neuk
- Treasurer
- Membership No: 806
Re: Oil change.
Check your user manual for the recommended oil and stick to it, it is probably VW 505 or 507 specification oil. I prefer using Shell and have for many years but I hear the Liqui Moly range is pretty decent.
Re: Oil change.
Im pretty sure its the 505, i also heard that the Liqui range is good but then again rather use what is tried and tested.
Thanks so much for the reply.
- Car Model: Sportline
- Membership No: 3194
Re: Oil change.
505.01
Re: Oil change.
Liqui moly are very good oils. They are more expensive and not available at a forecourt so perhaps buy some extra incase you have to top up.
Online
- 4ePikanini
- Car Model: Touareg R5
Re: Oil change.
505.01 or 506.01 or 507.00
However....
507.00 is better than 506.01
506.01 is better than 505.01
However....
Re: Oil change.
true when its comes to the ability of the oil, drain interval (longer life)4ePikanini wrote:505.01 or 506.01 or 507.00
However....
but i would rather stick to a 505 01 5w40 oil, i feel it would offer better cam follower wear protection which is what pd requires most
afaik the 506 and 7s only come in 30 and is pd approved but i still feel that 40 viscosity will help slow the wear
2007 Polo GTI
2013 Honda Ballade Elegance
1996 Honda Ballade 150i
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
2007 Polo 1.6 Comfortline
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Re: Oil change.
Please explain by what scientific principle does a oil that has a higher viscocity provide better shear protection on a cam?Jueshen wrote:true when its comes to the ability of the oil, drain interval (longer life)4ePikanini wrote:505.01 or 506.01 or 507.00
However....
So looking at JUST viscocity which is what you are saying.
Re: Oil change.
Hi,
my response was not a scientific one hence i stated "i feel" ...
wouldnt a 40 oil will stay thicker at higher temps than a 30, that would offer better protection to the lobe / roller, camshaft that wears on the PD motors..
i could be wrong hence this is a forum where we discuss, and have also read other forums and owners advice:
http://forums.tdiclub.com/showthread.php?t=367856
at the end of the day we can read it all, take advice and gather information to best make a decision we a re comfortable with
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Re: Oil change.
Re: Oil change.
Interesting read, Based just on viscosity I found that the the 40 rating was always better over the 30 even when compared to its own brand havoline 40 Vs havoline 30 which both have stable shear rates.
But that's just viscosity when shear rating is thrown in there is more to compare to. , I read something similar about shear ratings when oil is just new and how changing oil too early ain't good. Anyway can you give me a brand of fully syn 507.00 oil that is available locally and I will compare it to the fully syn havoline 505.01 oil that I use I will also compare it to the shell helix hx7 AV 505.01 that everyone uses which is not fully syn. I did a similar comparison with hfrr wear ratings with the diesel brands looking at technical datasheets
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Re: Oil change.
We use hx8 ultra (which you can have in 5w30 or 5w40). Not hx7. Assumptions makes .......
Re: Oil change.
tx will have a look
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Re: Oil change.
had a look at the specs both the ultra 5w30 and 5w40 only mention 502.00/505.00 not 507.00
will take a look at the bottle next time at GW
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Re: Oil change.
507 only required for cars with dpf.
http://www.myturbodiesel.com/wiki/engin ... di-diesel/
go and check the technical bulletin attached there - has shell ultra as an approved oil.
Re: Oil change.
thanks, i see in that link under "camshaft wear issues" he also suggests a 40 weight over a 30 to better protect camshafts..
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
2007 Polo GTI
1991 Citi Golf 1.3
2009 Citi Rox 1.4i
1989 Citi Sport 1.8
Online
- 4ePikanini
Re: Oil change.
HX7 AV is 505.01 specification.
507.00 is a better oil and supersedes all previous diesel specifications for VW/Audi diesel engines*
*except non-DPF R5/V10 Pumpe Duse engines due to the metallurgy of the big end bearings that require the additives present in 505.01 and 506.01 and not in 507.00.
- smitbrandon
Re: Oil change.
Thanks Panic, I have been looking for a article like this.panic-mechanic wrote:https://www.bobistheoilguy.com/oilshear.htm
