Help Passat B7 smoke and engine knock
Good Day,
I need your expert advice please. My 2013 Passat B7 TDI common rail smokes and knocks on first start every day. Here is a link to a video I took this morning.
https://www.youtube.com/watch?v=GmVHMttp3ok
Some background. In August the dreaded cambelt skipped a few teeth and the head got destroyed. I had the head replaced with a recon unit bought from SAC Engineering. The smoke and diesel knock problem started after that. The gentleman who installed the new head has no idea why this is happening. We even had all the injectors pressure tested and the are all ok. No errors on VAC.
This is happening only on the first start in the morning. The car has exactly the same amount of power, and the fuel efficiency has not decreased. Basically everything is the same as it was before except for the smoke and engine knock on cold start.
I welcome you to please help me brainstorm this. The cambelt issue cost me over R40k, so I cant spend much more.
Kind Regards
Gustav
Kind Regards
Gustav
Re: Help Passat B7 smoke and engine knock
possibly leaking / dripping injector. if an injector leaks or drips after shutdown you might have that issue on startup if it had dripped fuel in liquid form into the chamber.
Other than that have you checked for correct temperature in vcds ie. that it reports cold when it is cold.
Thank you for the response.
I don’t have a vcds to check. Is it possible to unplug the sensor so that it reports cold? If so, where can I find it?
no if you unplug the sensor it will jut cause another fault in the management
- Carel040
Hi Gustaf
Where are u based
Where are u based
Hi Carel,Carel040 wrote:Hi Gustaf
Where are u based
Im based in Pta.
- Carel040
Hi Gustaf het jy al jou problem op gelos
In pretoria contact thos guy. Trevor greene 0833095033
Hi CarelCarel040 wrote:Hi Gustaf het jy al jou problem op gelos
Nog nie.
Gustav
- Carel040
Ok Bel my pel Thavishen +27718701411 hy het VCDS Kan jou Kar scan en se wat die fout is
