Hi all,
Please assist, i have a jetta4 2001 1.9 tdi. It was parked of for two months. Now when i have tried to start it :
- it swings perfectly but does not start
- was a perfect running vehicle prior
- it has enough fuel
- i even put the fuel pipe direct to a bottle of diesel
- opened up the the nuts that connect to the injectors
- glow plug lights are fine
Please assist
jetta4 tdi issues
- Car Make: jetta4\polo tdi
- Car Model: 2001\2006
Re: jetta4 tdi issues
hi Romalan when you opened the nuts on the injector feul lines did it squirt out when cranking the engine?
- Tdi jetta 4 ever
Could be that your cranking speed is not fast enough or some fuel has run back the lines. Try a jump start or a fresh battery.
Robin
robinwisse@gmail.com
- Cass
- Car Model: Mk4 tdi
try starting it using your spare key
current: vw Golf mk4
1.9 Tdi
1.9 Tdi
