Hi Guys
I have a 2008 Polo 1.9TDI 74kw 5 speed, hatch. My car is on 180k and i just did the cambelt and full major service. I got her at 155k, and I am currently having an electrical problem.
1. I start and drive, After 5 Minutes my power steering goes off, Haven't checked the cable as yet.
2. I just replace my battery two days ago and added another ground from the battery to the gearbox.
3. When my lights are on,Everything is like Blinking, and the lights on the dash by the radio are going off and on, Everything still works, However she is running the battery dead and she doesn't want to start now and than.
4. I have tested the alternator and she is charging at 13 - 15 volts.
and that's all the problems i have for now, Loving the car, and i don't want to sell it, but i need help guys , Please help ! ...
Thank you
1.9TDI Electrical Problem
Re: 1.9TDI Electrical Problem
check the box with fuses on the battery for contact and the earths to the body as well. Gearbox is not grounded to the chassis.
Thank you, I put a ground cable from the battery to the starter which is on the gearbox, Should i move that ?panic-mechanic wrote:check the box with fuses on the battery for contact and the earths to the body as well. Gearbox is not grounded to the chassis.
- MarshallGTi
- Car Make: Seat
- Car Model: Ibiza 1.9TDi FR
- Membership No: 1665
Also make sure you're power steering fluid isn't low, the pump draws lots of current if its running dry.
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
Ibiza FR
Ex's:
ShoeBox
(o\!/o)
My mk2 16v
