Howzit guys
Hope i can get a few pointers to help sort out my issue.
I recently replaced my turbo with a new turbo as the old one gave in and once this was done the turbo kicked in only between 2500 and 2900 rpm and then only i could feel that turbo surge, but lately my car doesnt nt boost at all when accelerating I get this vibrating noise that sounds like it is coming behind the dash and then i stop accelerating also i can hear this hissing noise on the drivers side it seems.
I tried to see why I am getting the hissing noise and I noticed that the boost pipe that comes from the intercooler at the bottom going to the turbo came out slightly and I pushed it back and put the retaining clip on, i drove the car for a while and the boost seemed to start picking up again but I still get the hissing sound, I am at wits end.
Can anybody advise what could be the problem and recommend a someone who can sort out this boosting issue on the east rand as it affects my overtaking especially when overtaking trucks .
Will appreciate all your assistance
Boost issue on MK5 2.0TDI
- Car Model: MK5 2.0TDI
- Registered for: 8 years
Re: Boost issue on MK5 2.0TDI
Did you check the vacuum hose going to the turbo's actuator? Might be leaking and will affect boost or a boost leak in the boos pipes.
Panic Mechanic might be able to assist, he's also in the eastrand or close by.
Sent from my EVA-L09 using Tapatalk
Nope never checked the vacuum hose, will have a look at that, thanks for the reply. Do you perhaps have Panic Mechanics contact details
You can pm him on the forum.
He's very active and have helped me alot with advice.
061 507 6017 in business hours. Whatsapp preferred in daytime. No calls after hours.
