Hi tdi Engineers
Im driving a 2012 vw jetta 1.6 tdi
The filler cap is oily and it consumes too much oil
I thought it is the filler cap and replaced it but it seems im wrong
I will post pictures later today
Sent from my LG-H735 using Tapatalk
Engine oil filler cap oily
- Registered for: 9 years 4 months
- Car Model: Sportline
- Membership No: 3194
Re: Engine oil filler cap oily
Which seals(filler cap seals?)billionairebum wrote:Seals?
I had leaks coming from my filler cap and funnel. I replaced the seals and the leak went away. (9n).
Ok let me see what i can dobillionairebum wrote:I had leaks coming from my filler cap and funnel. I replaced the seals and the leak went away. (9n).
cannot look at that in isolation and say if it is problem or not. Pull the breather that comes form the sump and if there is excessive pressure there or huge amounts of oil in the intake then you might have a rings issue.
Ok thanks for the info
