Turbo Pressure limiting solenoid valve
- Car Model: 1.9Tdi Polo
Hi Guys,
New to the forum,
I drive a 2005 Volkswagen polo 1.9Tdi 125 000km on the clock,
i noticed the other night that i have very low Rpm's and that there is no boost like before,
i took my car in for a diagnosis and the error states ’Turbo Pressure limiting solenoid valve’’
i would just like to know if there is anyone that can tell me is it the solenoid itself or the turbo?
and can someone suggest a solution for this? do i take it in is it something i can fix myself.
your help will be much appreciated.
New to the forum,
Re: Turbo Pressure limiting solenoid valve
No error code number? Sound like n75 but can't be sure with what you gave
Sorry i completely forgot,
Info ECU
ECU G000SG 6118
ECU code 038906019ND 1.9I R4 EDC
ECU code 102
dont know if this might help?
i dont see any other codes on the report.
Info ECU
ECU G000SG 6118
ECU code 102
There must be an error number like P1056 or something.
Did You use vagcom or some egenric fault reader?
- Carel040
Hey dude where are u based
if you can pm me your email address i can send the whole report?panic-mechanic wrote:There must be an error number like P1056 or something.
Hi Carel040,Carel040 wrote:Hey dude where are u based
I am in the East rand, Nigel close to Heidelberg
- Carel040
Hi Leon just as panic suggests get your car scanned check vcds register you will find someone close that can help u solve your issues cheers
- Carel040
27718701411 phone my buddy that he can help u
well at least give him your buddies name or should he ask for 'Carel's buddy'
- Carel040
Thavishen Toxic tuning 071 970 1411
