1.6 Polo Tdi do not start
BrendanHeymans
Registered for: 6 years 7 months
Post by BrendanHeymans »
I have a 2014 VW Polo 1.6 tdi that does start only cranks the feul tank pump is not running and there is no power measured from the fuel tank power connector what can cause the problem
Carel040
Re: 1.6 Polo Tdi do not start
Post by Carel040 »
Did u check the fuel pump relay
Fuse
Relay
Crank angle sensor(ie management does not know the engine is turning)
Broken wire.
Can be many things. You can start by getting a vcds scan on it and try the output tests to see if the pump will run.
Then crank it and see if the management sees rpm.
