To buy or not to buy polo cross 1.6tdi 2010
Polo cross 2010 1.6tdi with 200000km on the clock, with full service history done by VW.
Is it good buy or not and when is time for turbo change, injectors change. And how much more or less for these replacements.
Any other expenses that I could be facing for the future
Thank you
Thank you
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Re: To buy or not to buy polo cross 1.6tdi 2010
Very expensive engine to sort out if things go A-walled
Turbo cost is around R7500 for the original unit (Garret)
Injector replacement cost is around R10k per injector
At that mileage you are at risk of the above, maybe have a good look at the history of the car other than its service history.
And they might or might not need it soon. You cannot know.
- Neuk
- Treasurer
- Membership No: 806
I wasn't aware the newer CR motors had such expensive injectors I know about the older PD motors injectors being expensive, new anyway.
- Membership No: 388
They not that troublesome. Injectors are dam expensive between 8 to 13k each but they don't usually give problems. Turbos don't give problems that quick.The actuator can give issues as it electronic and in most cases can be bought lose. Egr cooler can give problems and that's expensive.
Egt sensors I have seen a few times. Remember dpf has a life span too and that is a expensive item to replace unless u remove and remap.
All the above is what can go wrong and to keep in mind.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
- SemiColon
- I sparkle in the sunlight
- Car Make: Volvo
- Car Model: S40 T5
- Membership No: 1641
Don't forget the DPF can give issues ~R25k
So worse case, R80k.
八拾六
Thanks for input guys, so a standard 1.6 petrol will be much better.
Seems that would be your best choice. I have read too many (and especially expensive) issues with turbo VW engines.Thanks for input guys, so a standard 1.6 petrol will be much better.
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
All makes of cars have some issues. And all makes of turbo cars have some issue. It is not restricted to vw. Just remember that a turbo charger is not actually made by vw and is supplied by basically a few big companies across the world. Garrett/kkk/ihi so failures happen and to say that it is a vw only thing is a bit silly. But actual turbo failures are a lot less than it was years ago and quite a bot of it can be attributed to how the user treat the thing.
- Neuk
- Treasurer
Care to share the stories? I have had three different VAG based turbo engines and not a single days issues so far...HendrikCTI wrote:Seems that would be your best choice. I have read too many (and especially expensive) issues with turbo VW engines.Thanks for input guys, so a standard 1.6 petrol will be much better.
I agree Panic. As this is a VW forum, I decided to keep it brand specific with my statement.
@Neuk. I have read frequent problems of turbo failures\problems on TDi's and on GTi's. Some with lowish km on the odo compared to naturally aspirated engines. The problem I have with this is that it can happen unexpectedly. A good example is when your car is loaded with family and you are on the open road on your way to a holiday destination. Yes, I know, a naturally aspirated car can also have a failure. my second reason is that these failures seem to be quite expensive to repair. For me a car is transportation from point a to point b and must be the most economical and reliable manner of transport.
Each one I think will have a different viewpoint on this but I am still a old school guy. I will always prefer naturally aspirated. It is technology that has been around for many years. I'm not convinced yet that turbo cars is as reliable, but it seems lately the engineers are slowly starting to get it right.
1977 Datsun 1200GX
1977 Datsun 1200GX
- Car Make: Toyota
- Car Model: Corolla D4-D
- Membership No: 2016
Friends one has 300000km+ never changed injectors.
Sent from my iPad using Tapatalk
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
2006 Toyota RunX
- Neuk
- Treasurer
This, tells me the most...HendrikCTI wrote:I agree Panic. As this is a VW forum, I decided to keep it brand specific with my statement.
I really don't hear of massive issues with turbo's these days, nothing like the E46 320d or 9n Polo PD130 failures. Turbo's are an additional failure point on an engine for sure but unless you have terrible luck or neglect to look after your car, these days there shouldn't be any reason why they aren't as reliable as N/A motors. Having said that though, I won't own a modern day high performance turbo car out of warranty/maintenance plan at this stage in my life, the costs to repair some of even the most simple issues are exorbitant.
I agree.
Thus the reason I recommended to him that a naturally aspirated will be a better choice. It starts to get expensive to keep a car in a maintenance plan the more km you clock on it. There comes a point where one have to bite the bullet and hope for the best and just drop the maintenance plan and look after your car yourself. This unfortunately is difficult to do for most people with turbo cars due to repair costs involved should something fail.
1977 Datsun 1200GX
1977 Datsun 1200GX
I keep a mixture of n/a and turbo cars so there is at least always something to drive. But in lots of cars and many km travelled I only had one turbo failure and that was in a golf 4 tdi. And yes on the way to a racing event weekend away. Had to get it towed home and take another car.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Howie brother car is sitting on over 200 000km and still going strong.
- Membership No: 2033
285 000 km's (it is the 1.9TDi 74kw Cross), there is another one on the BB over 300 000km's as well. VGTI, I think??Unobeat wrote:Howie brother car is sitting on over 200 000km and still going strong.
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Unobeat
Howie-WP wrote:285 000 km's (it is the 1.9TDi 74kw Cross), there is another one on the BB over 300 000km's as well. VGTI, I think??Unobeat wrote:Howie brother car is sitting on over 200 000km and still going strong.
Correct his car has some special masala mix, it is over 350 000km currently and still running the OEM turbo and clutch.
