2010 VW Polo 1.6 TDI Major Repairs / etc
malphil
Registered for: 9 years 9 months
Post by malphil »
Hi all its me again
I am starting this thread for future reference for everyone to use etc. I will list all the things I fixed and changed with my car from 2010
Little background - Own the car from new, (7Km on clock)
11000 km had to change the heater turn switch
Up until 150 000 km only the basic services where done. (belts oils etc)
155 000 km (round about there) Thrust bearing started making a noise and I had it replaced, (was suppose to be full Clutch kit / flywheel etc)
Found out they only did clutch and thrust bearing.
190 000 km replaced Air intake sensor + all 4 Injectors (quite pricey as some may know)
Car is now on 201 000 Km and it is sounding like the thrust bearing is packing up again, although it sounds a lot worse this time, took it to a mechanic i trust and he said its flywheel ? I can hear the sound when the car is idling and it is softer or disappears when i press the clutch. (Almost like grinding noise) any ideas if it is the flywheel?
So now I will probably do a whole kit again.
Still love this car to bits, It has served me well and will serve me until 400k km probably!
amstel18
Car Model: Tiguan Allspace
Re: 2010 VW Polo 1.6 TDI Major Repairs / etc
Post by amstel18 »
Definitely the flywheel.
My dad's Corsa Diesel did exactly the same. The Dual mass flywheels have almost like a rubber substance between the 2 plates. This wears away and causes the chatter you described. Best to replace the clutch and thrust bearing again. I would do the rear main seal as well while you in there.
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
Registered for: 13 years
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
@malphil
Great feedback.
Seems the car has treated you well with not a lot of issues.
Did it accumulate majority of those kilos on highway driving doing long distances?
malphil
Post by malphil »
@Unobeat
Jip was mainly highway driving and 7 trips thru Botswana to Outjo in Namibia. Did those Namib trips towing a 5 foot Venter without any problems
LoW n SloW
Post by LoW n SloW »
Your mechanic is probably correct sounds like its the flywheel of which in any case you will need the whole clutchkit
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
malphil
Post by malphil »
Hi All just to give an update, Polo went for a check its definitely flywheel, bought the SACHS kit yesterday polo is going in tomorrow, hopefully everything will be all good after the change!
Pynoxim
Post by Pynoxim »
All the best with that, hopefully no more issues for another 200k km's
Thursday Milkshake Crew
'00 GS2 Lexus GS300
malphil
Post by malphil »
Morning all, Mechanic phoned me this morning, I must come fetch car he is done.
Money spent
SACHS - CLUTCH - R6845
Fitment - R1050
Total spent R7895 not too bad I recon for a completely new clutch-kit and fitment
New Problem
Flashing glow plug light and engine light (again) - Mechs says the computer say its oxygen sensor and exhaust sensor? Any input?
malphil
Post by malphil »
Hi All, just to give an update, My polo will be going for its 210K km service soon, things that has happened since and what I have to fix now
- Changed EGT sensor with second hand one(did not last long) replacing with new one now
- Moerse shudder while braking (Time for new disks had them skimmed before)
- Knock sound when pulling away and even harder knock when reversing and the pulling away, probably the gearbox mount saying goodbye
What are the long term affects if i dont change the EGT sensor? Car is all of a sudden averaging about 21Km/l (during long trips)
it will be slightly down on power as it will probably pull a little bit of fuel to be safe for the turbo.
malphil
Post by malphil »
Came back from Durban this weekend, went to fetch the Polo at Mechanic, few niggles that still needs sorting
Return line at Injector leak off, keeps popping out, so it might be one of the following
- Either clip that keeps it in is not doing its work
- Or there is a blockage somewhere on the return and it keeps popping at weakest point
Just another question, when this happened it pump diesel all over the engine, with what can I clean the motor?
And what is the use for the hood insulation, mine is coming loose at he back of the hood and is starting to lie on the engine cover when hood is closed??
They probably broke the clip.
Hood insulation is for noise.
malphil
Post by malphil »
Where can I buy a new clip?
Probably have to buy the whole pipe. Check with goldwagen or vw dealer. But who did the work should really have sorted it if they were the ones to break the clip. No honour anymore.
malphil
Post by malphil »
Thanks Panic, the injectors were replaced at 190 000, so it was fine until now, and all off a sudden this now happened, but will ask the mechanic about it(different Mechanic now working on the car) goldwagen said I must call VW as they dont have those parts, VW quoted R1385 for all 4 injectors return pipes.
malphil
Post by malphil »
Hey Guys, just an quick update, car went for its service last week, (224K Km) dont know if I told you the following
I have taken the Car to JNES TUNED cant seem to remember when think round about 212K but anyway, also had DPF removed and CAT, and had car mapped , but asked Jannes to map for fuel consumption, as I am past my racing days, car now has a bit of a smoking habit with every start it in the morning but disappears when the car is warm, also gives a nice puff if I hammer it in 3rd / 4th gear when overtaking. So far so good car has been extremely light on fuel, getting close to 1200km per tank.
I am still driving with a engine light on, it seems it is an exhaust sensor, but was just to lazy to source it and replace it.
8VALVE-zn
Car Make: VW Golf 1
Car Model: 2.0 h8 valve
Post by 8VALVE-zn »
It is pretty normal for it to throw a bit of smoke on start up after a remap, its has to do with the change in fuelling on the map. On mine, it would smoke for about 2-3 seconds and then nothing thereafter when warm. Did you do a full downpipe on the car to eliminate the DPF? I actually got the dpf flowed on my one, it changed the sound of the car in a minimal way.
muloiwak
Registered for: 8 years 9 months
Post by muloiwak »
These are the things that failed on mine, sold it at 140 000KM though
-EGR cooler - R14k(Warranty claim)
-Mass air flow meter - R3k(Warranty claim)
-Boot lock - R2k(Warranty claim)
Other common failures on these
-Piezo Injectors - Quite expensive - R5k per injector, this excludes labour, you need a very good mechanic to replace these, code and adapt them, Genuine injectors are R12k each
-DPF - you can just get a DPF delete done
