TDI going crazy!!!!!! cam crank cam sensor.Polo 2005
Jakkels85
Registered for: 10 years 9 months
Car Model: Mk1 2 door 16v turbo
Post by Jakkels85 »
HI Guy's
Where to start, okay Feb 26 the car blew the first cam sensor, i replaced it with one from goldwagen car was running fine until the 28 March then it blew the cam and crank sensor, I replaced both with goldwagen sensors and drove for about 900km. Saturday we went to JHB randburg area car was running fine then when we wanted to leave the afternoon the car did int want to start so my first thought was cam sensor as i suspected unplugged it and broem it started. Drove to spring no hassle on sunday morning went for breakfast as we left the wimpy the hand brake light came on with the ABS light then the glow plug light i lost power steering so i switched the ignition off started it up again and everything was fine. That evening i drove back to rustenburg car was fine (cam sensor still faulty). Monday i went to Goldwagen again got a new sensor replace it but did int plugged it in............. on Monday night on my way home the car lights dimmed twice and then it started doing it again i switched off and started it again then i realized the clock inside the cluster was out km range was on 0 km. i have check the negative and positive and all the fuses on the battery. I took the car this morning to Bruno's in RTB guy phone me and told me every thing is fine he did a diagnostic no faults nothing i need to buy a original part cam (sensor)from VW. Please is one of you guy's have had a similar problems or so i will appreciated if any of you could give me advice on where to look.
vee4410
Registered for: 8 years 5 months
Car Model: Polo 9n3 1.9 TDI, 9n 1.6
Re: TDI going crazy!!!!!! cam crank cam sensor.Polo 2005
Post by vee4410 »
Possibly a faulty alternator.
2007 Polo 9n3 1.9 TDI
2004 Polo 9n 1.6
2015 MB w205 C180
Jakkels85
Post by Jakkels85 »
Okay will check the amps and voltage. We did a diagnostic everything shows fine but will test it. Thanks.
VGTI
Registered for: 18 years 7 months
Car Make: Cheap Ass Porsche
Car Model: 9N Sooter
Membership No: 807
Post by VGTI »
Mine did that a few times... replaced the battery!
SoDub
Chairman
Chairman
Car Model: Seat Ibiza Cupra 20VT
Membership No: 1998
Post by SoDub »
The losing of the electrics and everything resetting to 0 is something I had on my TDi. My issue was the main earth strap from the battery. Cleaned the contact up and reattached it and it stopped doing this.
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
Caddyon
Car Model: Polo 9N3 1.9Tdi Sportline
Membership No: 2025
Post by Caddyon »
Almost certain this a voltage issue / faulty earth
Tyrone - SR Tuned - http://www.facebook.com/srtuned
Current 06 9N3 Sportline - 1.9 BIG TURBO TDi SRTuned / Profiturbo.com
Power Figures 221wkw and 569wnm
Dezzi Drags = Boost + Diesel, no gas : 12.5
Current 2010 KTM 200 XC-W
Ex=Vw MkI Citi
Ex=Ford Ranger 2500Tdi 4x4 Supercab
Ex=Vw Caddyon 2.0 8v
Ex=2001 Vw Jetta 4 v5
Ex=2000 Opel Corsa GSI
Ex=1967 Ford Anglia 1600 Sport
Ex=1999 Opel Corsa Ute Chin Scraper
Jakkels85
Post by Jakkels85 »
Thanks guy's will double check the earth cable and make sure its clean battery was replace last year July. Holy shoot got the price from VW
R 1920 for a new sensor but surely this does int make sens because the oke tune me wiring everything looks good on the car i need to replace with original sensor but hell what if it blows again. I rather take the car some elsewhere because these guy's just want your money and don't fix the problem.
Jakkels85
Post by Jakkels85 »
Hey guy's, Okay so i got the new sensor on friday last week from VW and replaced it so the Freeking car is doing the same. I striped my m@er and stripping the car checked all the wiring from the cam sensor plug to the ecu and loosen all the negatives and cleaned them checked all the plugs and sprayed the with electro cleaner as well. I have check the continuity on the wiring form the cam sensor plug to behind the plug and from their to the ecu unit no faults found. so i stared the engine without the cam sensor plugged in, when i plug it in the engine stall WHY??????? So after i striped half of the car phone a friend of mine he told me the timing can be out is this true.
marzbars
Car Model: 1988 Corrado 16V
Membership No: 1316
Post by marzbars »
Everytime a TDI goes electricrazy it is the earth strap on the battery.
Jakkels85
Post by Jakkels85 »
Okay after speaking to a dozen of people and costing me a couple of bucks we got the FREAKING problem.
Timing was 100% but had to adjust the cam timing a bit on the cam pulley to get it to respond with the cam sensor. The error we got from the ecu was cam position sensor out of range when the timing is 100% on it mark so after a 2 hour friggiling with the thing back and four f we got the cam and ecu to connect and start as normal as any tdi should. I drove the car it pulls normal and drive like should.
Will give you guy's updates if their is any funny stuff going on again.
Cheers.
collenpitso
Post by collenpitso »
hi guys
i am having the same problem bra- dont know what to do
Caddyon
Membership No: 2025
Post by Caddyon »
read the advice above and you will know :)
Ex=Vw MkI Citi
