1.9TDI ASZ Single Mass Flywheel
Hi, anyone here using a single mass flywheel in their 1.9Tdi 96kw ASZ.
- Committee Member
- Car Model: Audi S3 Sedan
- Membership No: 1215
Re: 1.9TDI ASZ Single Mass Flywheel
Lots of people are, Why?
Personally I wouldn't if its a daily
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
G-spot wrote:Lots of people are, Why?
Why would you not as a daily?
- M@rk
- Car Model: 1.9 Tdi Sportline
- Membership No: 1776
I don't know one member on the forum that use the Single Mass flywheel.
Single mass fly wheel chatters at idle and would drive one crazy thus its not recommended as a daily drive bu good for performance tho
- BIGMIG
- Porra Love
- Membership No: 1574
Metsu has a southbend stage 2 clutch and SMF. IIRC he said it had some slight chatter but due to pairing the clutch with their SMF it was reduced.
But agreed I haven't seen any other members with a SMF wheel.
- BatteryWorldPtaEast
- Car Model: Polo TDI Sportline
- Membership No: 1572
Have been using 1 for the past 7 years and it was a daily drive.
As they say it is noisy but that is up to you.
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
- dhirennaidoo
- Car Model: 9n Polo Classic TDi (PD100)
On slip, on idle, or all the time?BatteryWorldPtaEast wrote:Have been using 1 for the past 7 years and it was a daily drive.
'08 350Z
'05 Polo Classic TDi (PD100)
Ex : '12 Mk6 GTi Ed35, '91 Fox 1.8, Honda CBR600F, '09 Honda CBX250 Twister
- Caddyon
- Car Model: Polo 9N3 1.9Tdi Sportline
- Membership No: 2025
i would personally just stick to dmf
Tyrone - SR Tuned - http://www.facebook.com/srtuned
Current 06 9N3 Sportline - 1.9 BIG TURBO TDi SRTuned / Profiturbo.com
Power Figures 221wkw and 569wnm
Dezzi Drags = Boost + Diesel, no gas : 12.5
Current 2010 KTM 200 XC-W
Ex=Vw MkI Citi
Ex=Ford Ranger 2500Tdi 4x4 Supercab
Ex=Vw Caddyon 2.0 8v
Ex=2001 Vw Jetta 4 v5
Ex=2000 Opel Corsa GSI
Ex=1967 Ford Anglia 1600 Sport
Ex=1999 Opel Corsa Ute Chin Scraper
Ex=Vw MkI Citi
- saxo
On idle you will have the noise.
Sometimes its loud, but lots of guys with the 5 speed boxes use the abf smf and they are happy.
- MeanTdi
- The Imposer Mod-whore-rator
- Registered for: 18 years
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
http://www.vwclub.co.za/forum/viewtopic ... 4&t=143096
Some reading:
http://www.vwclub.co.za/phpbb3/viewtopi ... el#p949939
http://www.vwclub.co.za/phpbb3/viewtopi ... s+flywheel
http://www.vwclub.co.za/phpbb3/viewtopi ... lit=clutch
http://www.vwclub.co.za/phpbb3/viewtopi ... 3&t=104484
Some reading:
&BatteryWorldPtaEast wrote:Some reading:
Some notes on application pros and cons:
The dual mass systems are designed to transmit less engine vibration to the driveline, and give a better more car like driving experience. They also reduce some of the jarring and stress on the transmission and remainder of the drivetrain. They work fine as long as the engine remains unmodified and the vehicle is not used/abused beyond manufacturers recommendations.
As soon as you start to increase the engine power over stock, or load the vehicle beyond design parameters, you run into problems. Dual mass flywheels are tuned systems and must be matched to the engine torque curve, engine resonant characteristics, vehicle load curves (including axle ratio/tire size calculations). They work by having a set of springs inserted between two rotating masses (thus dual mass). The springs are sized to soak up some of the resonant vibration from the diesel engine under load conditions. A dual mass fly wheel generally also contains an over torque friction release, so if it gets suddenly overloaded, rather than damage the springs, it slips. This works fine as a safety valve, but if it does it much it burns up. In short, overloaded they burn up and the springs get destroyed and they are worse than if it were a single mass FW.
The single mass part WILL tend to transmit more engine pulse (vibration) tot he drivetrain, and will seem a bit rougher. But it is straight forward to design a single mass flywheel and clutch package for pretty much any engine torque curve and vehicle loading combo you can come up with. Drives more like a TRUCK, but has much better reliability at extreme use levels.
&BatteryWorldPtaEast wrote:The DMF is gone and is no longer taking the vibrations from the engine away but is now pushing it through to the gearbox ,my single mass flywheel sounds the same.Nothing wrong with the gearbox.
If the release bearing is faulty it will make a noise when you push the clutch in and release it ,not when the clucth is released and gearbox is in neutral.
&BatteryWorldPtaEast wrote:Pros :Grips like hell with no fade.
Easy gear changes,like the normal clutch.
Cons: Not easy in peak time traffic ,your leg goes num
The slave cylinder did not last long ,will be changing it soon.
The chatter from the engine can be heard, so the diesel sound is louder.
Other than that it performs well.
Will check for you.
MeTsU wrote:They are very good kits indeed DieselTorqueTdi. Ramster, you most certainly don't want to go much lighter with regards to flywheel, as you'll loose loads of torque. I know of a few guys who have gone for a lighter flywheel, and are very happy. Remember though, that diesels don't like to rev high, and the advantages of having more HP up top due to reving cleaner, are outweighted by the disadvantages, like running bearings. Unless you have a built motor, of course.
BatteryWorldPtaEast wrote:As the topic says "solid flywheel" and they have 1 for your car too.
FST 228MM L/W Aluminum Flywheel W/ SACHS VR6 CLUTCH KIT for 5-Speed (FITS VW MK5 JETTA RABBIT BEETLE W/ 2.5) Stage 1
Part Number: K7003802.FST107904-11T
Price: $559.95
Description: Total overall weight reduction is 9.7 pounds. OEM kit complete 32.8 lbs. FST Kit 23.1 lbs. FST flywheels are made of 6061-T6 heat-treated aluminum plate. It also features durable 1050 steel friction plates, with aircraft grade bolts and nuts. The ring gears are heat-treated, pressed on, and then secured with grade 10 fasteners.Replaceable steel friction plates also sold separately.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- BIGMIG
- Porra Love
Great job finding that Marco.
- chalmers95
- Car Make: VW polo
- Car Model: Polo 1.9 ASZ stage 2
Good Afternoon All,
Where can I buy the SMF as a complete kit or just the SMF?
- Car Model: Polo TDi
From Lmb i think they go as mbt automotive in Johannesburg. Majority of the Big turbo TDi's are running this setup
Sent from my LYA-L29 using Tapatalk
