TDI - Just swings not starting
SpikePCR
Post by SpikePCR »
need some help. I bought a 2003 1.9tdi golf 4 estate. Today I get stuck on Rivonia road. Car just switched off while driving. Only swings. No fault codes appearing on my Torque app. I did do a service over the weekend. Normal filters and also the diesel filter. I have done +- 1000km since. What should I look out for. Thanks in advance. Mileage is on 221000km
Solo786
Registered for: 17 years 1 month
Car Make: Porsche,BMW,VW
Membership No: 1251
Re: TDI - Just swings not starting
Post by Solo786 »
hope it didnt break a belt
is the diesel pump fine? or does this use pumpe duese technology?
SpikePCR
Post by SpikePCR »
Solo786 wrote:hope it didnt break a belt
according to service records belt was done at 190000km by bruma VW last year May. I did check if diesel was pumping and the one clear pipe from the diesel filter i can see fuel move.
Solo786
Membership No: 1251
Post by Solo786 »
ok, check the EGR valve bud.. could be stuck
SpikePCR
Post by SpikePCR »
Solo786 wrote:ok, check the EGR valve bud.. could be stuck
Will do. will this not throw a vag error code
Solo786
Membership No: 1251
Post by Solo786 »
wont necessarily throw a code, its vacuum operated.
it gets stuck with the soot and carbon.
SpikePCR
Post by SpikePCR »
Solo786 wrote:wont necessarily throw a code, its vacuum operated.
thx will check it out asap
SpikePCR
Post by SpikePCR »
Had a look at the EGR Valve. If I push it in and swing then the swinging has a different noise when egr is in or out. Still swinging. How will I know if that valve is faulty.
Solo786
Membership No: 1251
Post by Solo786 »
do you have the ALH engine? if its a spring loaded type valve you can test with a vacuum pump. remove the intake pipe and apply suction, it should open.. when you release the suction it should fully close... if not you have a problem.
I think its worth a shot to remove that inlet pipe, remove egr, clean up everything and re install and try again.
If no luck we will look elsewhere, but you already said you could see the diesel flowing.
SpikePCR
Post by SpikePCR »
Solo786 wrote:do you have the ALH engine? if its a spring loaded type valve you can test with a vacuum pump. remove the intake pipe and apply suction, it should open.. when you release the suction it should fully close... if not you have a problem.
I have the ASV engine. Golf 4 1.9tdi estate. I will quickly clean it and see. Will it help if I do the EGR delete?
Solo786
Membership No: 1251
Post by Solo786 »
hmmm.. dont think the EGR delete will do much now. Get it started first.
Check the ASV inside the intake pipe is not stuck closed - force it open with that actuator on the side and try to start..
When you turn the ignition on do you see the glow plug light illuminate and go off again? If not check relay 109 - known to go bad.
Check your fuel system has not got some kind of airlock, try bleeding it from the filter - there is a T bypass valve there.
SpikePCR
Post by SpikePCR »
Solo786 wrote:hmmm.. dont think the EGR delete will do much now. Get it started first.
Will check relay 109. Glow plug light comes on then goes off after -+ 3s. How would I bleed the system with the t piece on the filter
Solo786
Membership No: 1251
Post by Solo786 »
so the relay is fine then most likely,
sometimes you can remove the bypass valve and have a look at the element inside the filter - if its relatively dry it could be an airlock issue..
other than that check the asv inside the intake pipe and clean everything, check the vacuum lines are good and not perished so as to not actuate the valves
SpikePCR
Post by SpikePCR »
Solo786 wrote:so the relay is fine then most likely,
I opened the t piece the filter looks dry I can't see any fuel in it. If I put my finger in then it feels a bit damp. Should I be seeing physical fluid
Solo786
Membership No: 1251
Post by Solo786 »
yes i would think you should have fuel in the fuel filter...
I think you have an airlock
Scatman
Car Model: 320d Msport
Membership No: 1773
Post by Scatman »
Get some diesel and fill the fuel filter up. Park the car so the nose is facing down. If the filter is full of diesel, re-insert the t-piece and have a go at swinging the motor and see if it starts. If it doesn't start then, I fear the seals in the mechanical diesel pump may be fubar because of running dry (but this in unlikely). These cars don't have a lift pump in the tank, so you need to get the lines and filter full of diesel before it can suck out the air bubbles that may be in the filter/lines.
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
SpikePCR
Post by SpikePCR »
Filled the diesel and still no start. Had a guy come out with a full mobile diagnostic and the error was diesel timing off. Mechanic bled the system and still no start. Opened the cambelt cover from the top and saw the belt that looked fine. Took the full cambelt cover off and upon further investigation we saw the cambelt tensioner was broken and the belt was loose at the bottom side :(. And the timing was off by 2 tooth. Hope the head is still fine :). Towed the car to a mechanic to do the cambelt change hoping that the valves are not bent :(. Cambelt was done last year may at VW bruma so no warranty. Mechanic said he will put the cambelt kit in and set the timing and hope it starts.
Solo786
Membership No: 1251
Post by Solo786 »
sheet... unlucky.
Hopefully the valves are still fine
Scatman
Membership No: 1773
Post by Scatman »
Damn that's a crap one bud! Two teeth aren't a lot, let's hope the valves are fine!
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
SpikePCR
Post by SpikePCR »
Scatman wrote:Damn that's a crap one bud! Two teeth aren't a lot, let's hope the valves are fine!
Im hoping so too :)
LoW n SloW
Post by LoW n SloW »
sorry about that man, usually i prefer having me to take the car for a cambelt service...cause previous owners lie about the history
hope you come right bro
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
BIGMIG
Porra Love
Car Model: 9N3 GTB22/60vk Sportline
Membership No: 1574
Post by BIGMIG »
Mine skipped a good couple and no damage to the valves or the head, very lucky I was. In your case if its only two then you should be ok.
Holding thumbs for you.
My NoPiel assassin
Goose, soot ninja
SpikePCR
Post by SpikePCR »
Cambelt kitt done and car starts :). No head damage thank God. What causes an oem tensioner to break after 15month and +-30000km
Scatman
Membership No: 1773
Post by Scatman »
SpikePCR wrote:Cambelt kitt done and car starts :). No head damage thank God. What causes an oem tensioner to break after 15month and +-30000km
I would imagine over-tensioning the belt would cause premature wear or failure.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
SoDub
Chairman
Chairman
Car Model: Seat Ibiza Cupra 20VT
Membership No: 1998
Post by SoDub »
or they used the old tensioner?
El Toro
2009 Seat Ibiza Cupra 1.8T(El Toro)
Blossom
2007 Seat Ibiza Cupra 1.9TDi(Blossom)
Turbo Killer Sportline
2007 - Polo TDI Sportline
"I live my life 1 turbo at a time."
