cold start problems
- Car Model: jetta 5 1.9Tdi
cold start problems
Hey guys
Ok my jetta 1.9 TDi stuggles to start if it was standing for a while.
I already put in new glow plugs and didn't help much.
I was thinking of changeing the injector seals.
I think its loosing preasure there then the diesel runs back and that's why I struggle to start it.
Has anyone done the seals by them self?
Any advice???
Any advice???
- Car Model: Golf MK1
Re: cold start problems
whats the mileage
its on 138 000km
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Psycho8v
- Car Make: Toyota
- Membership No: 1881
Alex, I can't find that other thread now. There was a guy also battling with a tdi (starting issue) a while ago, a 1.9tdi polo IIRC, was something like a cam sensor or something? Can it be something like that?1.9TurboVw wrote:Must be fuel running back
Check here: http://www.vwclub.co.za/phpbb3/viewtopi ... 8&t=157397
cheapest thing to do is to first replace the water temp sensor,and then go the route of replacing the seals on the injectors, also your cam timing ca be slightly out,was your cambelt done at 120000km? and if the injector seals are leaking you should find diesel contamination in the oil pull the dipstick and smell it that should give you a good indication whether or not the seals are leaking
- AlexTDi
Camshaft position sensor.. It's probably not that but If the other solutions don't work I suggest that stukkendeTdi gets it scanned with VAGCOM as it will pick up the error of the sensor..Psycho1400 wrote:Alex, I can't find that other thread now. There was a guy also battling with a tdi (starting issue) a while ago, a 1.9tdi polo IIRC, was something like a cam sensor or something? Can it be something like that?
If the issue is really more serious then yea maybe water temp sensor or like you said seals but its more then likely not the issue.Ronnie G wrote:cheapest thing to do is to first replace the water temp sensor,and then go the route of replacing the seals on the injectors, also your cam timing ca be slightly out,was your cambelt done at 120000km? and if the injector seals are leaking you should find diesel contamination in the oil pull the dipstick and smell it that should give you a good indication whether or not the seals are leaking
First step is to test if it is fuel running back, Park the car with the bonnet at the lowest position on a down hill, even 2 - 3 degree incline will work, Leave it over night then see if the car starts first swing, If not try a bigger incline.. If still not then fuel is not the issue.
If the incline works park the car like you normally would and make sure the problem returns so that you can pin point it to being the fuel running back.
If it does struggle that morning go past Diesel Electric and buy that one way return valve for the R95 install it and all should be hundreds again.
I also recommend testing your battery as TDI's require alot of cranking amp's to start up and batteries takes a big knock in colder weather.
Ps. My neighbours Golf 4 TDI is suffering with the exact same fuel running back and the incline thing worked.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- slumiesboi
- Car Model: Polo 9n 1.9TDI
Yeah that was my TDI, it was the camshaft position sensor. But it started fine when cold and after standing for a while. It only struggled to start after short trips and would die out randomly when driving.Psycho1400 wrote:Alex, I can't find that other thread now. There was a guy also battling with a tdi (starting issue) a while ago, a 1.9tdi polo IIRC, was something like a cam sensor or something? Can it be something like that?1.9TurboVw wrote:Must be fuel running back
Check your diesel pump and check for leaks in the fuel line
If it's broken, upgrade it
Mods: Revo_Decat_17" TSW MAX wheels
- BatteryWorldPtaEast
- Car Model: Polo TDI Sportline
- Membership No: 1572
Hi , check the Tandem pump on the side of the head ,it must be leaking diesel and letting air in the system.
Might look like this 1.
Hope it helps.
Hope it helps.
Daily drive : Polo TDI Sportline 180 Hp 349 Nm ATW (Trevor's Custom Map) At Night Dyno
Wife's : 1.9 Tdi Touran
Son's : Cross Polo 1.6 Tdi
Thanks for all the advice I will try them.
Can I ask Alex to give me a shout I would love to talk to you
Email me pls gerritpvn@gmail.com I would like to know where to put that one way filter .
- Tdi jetta 4 ever
Does it start easy when it is warm?
Robin
robinwisse@gmail.com
- AlexTDi
Hey bud,stukkendeTdi wrote:Hi guys
Speak to Chuck_norris and check this thread http://www.vwclub.co.za/phpbb3/viewtopi ... 8&t=157397 I haven't installed one myself so wouldn't know.
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
