Disadvantages of a bigger intercooler
Killerwatt
Car Model: S3
Re: Disadvantages of a bigger intercooler
Post by Killerwatt »
Ideal otto assumes you are not knock limited like most turbo motors are.
The main benefit of cooler air is to get to minimum best timing under fuul boost. this lets you get peak cylinder pressure at i think 12 degrees after tdc. that allows you to extract the most work from the gas and thus the lowest possible egts.
Gansnek
Registered for: 13 years 7 months
Car Model: 330e
Post by Gansnek »
I think Impi's explanation makes a lot of sense. He also said that this is not as noticeable as on older cars and also said that he was talking in extremes.
If you are fair and just consider what the man is trying to explain, you will see that it makes sense.
Now come, flame me... :tosser:
Current: F30 BMW 330e '17, F30 BMW 320i '14
Ex: Kia Sportage '13 (POS)
Ex: Candy White G6 GTi '10 Stage 2
Ex: United Grey G5 GTi '08 KO4
Colder air is denser than hot air. So the cooler the air you can put into the motor the more fuel you can burn. Any gain in hp always comes from 1 place only and that is the ability to burn more fuel. So once you have colder air you will be able to add fuel which will bring the egt's right back up. The only time you will have a drop in egt is if you now don't add the fuel that you are able to and if you don't do that what is the point of putting in a bigger cooler. Clever modern managements will add the fuel and the timing to make the most of cooler air thus the egt's won't drop. There is of course such a thing as putting a too big intercooler in so if you have a certain size cooler and x- intake temp and you install a bigger cooler and intake temp stays the same then there in no gain in the bigger cooler. From that point you are farming backwards.
Killerwatt
Car Model: S3
Stephan, wouldnt that only be the case if your motor was running at stoich?
If it is rich under boost, and it should be, then the colder air will lean out the mix and raise egt. Assuming that you or the ecu did not compensate.
In this case more fuel will then lower egts, right?
Killerwatt
Car Model: S3
ps im talking petrol motors there.
Just realised this is tdi section. In which case more fuel, more egt....
TDIbomshell
Registered for: 11 years
Car Model: 1.9 TDI
Post by TDIbomshell »
hi all
i'm new to this forum, and need some advice pls.
where can I find a nice intercooler with the mounting hole for the air sensor.
all the ones I have found don't have any thing and needs mods......pls help :crazy:
1.9TDI ,63mm s/s pipe, chip, intercooler, KO4 turbo
Psycho8v
Registered for: 13 years 8 months
Car Make: Toyota
Car Model: Corolla Quest 1.6
Membership No: 1881
Post by Psycho8v »
TDIbomshell wrote:hi all
Well, I'd start off by introducing myself in the introduce yourself thread, where we'd tell you to fill in the location field in your profile, so that people will know where to send you, then please also state your mode of transport, or give more details as the field in mechanics are wide, and modes of transport even more so. Other than that, welcome and enjoy your stay. And beware of whose thread you hijack, some people don't like it. :hi:
Sinbad
Registered for: 16 years 5 months
Car Make: Mercedes
Car Model: R170 AMG Hairdryer
Membership No: 1152
Post by Sinbad »
Neuk
Treasurer
Treasurer
Membership No: 806
Post by Neuk »
And here I was, getting ready for another debate about a rather technical topic, when all that was needed was a drill...
TDIbomshell
Car Model: 1.9 TDI
sorry. its for a polo 1.9 tdi 2006 model
TDIbomshell
Car Model: 1.9 TDI
and the drill thing is good. but can't one buy one ready made??
Yakuza Racer
Voora Molester
Post by Yakuza Racer »
check here mr tdibobshell.... dont you rather want to start your own thread somewhere else??
My new cooler is in the mail, and all that know the tiny IC the scoob has, so by getting a much larger FMIC i can effectively up the boost more and fuel more to make more ponies, but as said this can only be done with after market management.... so first fit and then tune?
low boost is .08-.09 , high boost is 1.2....
Thupercharged S4
Balls
Membership No: 1708
Post by Balls »
yakuza racer wrote:check here mr tdibobshell.... dont you rather want to start your own thread somewhere else??
:hijack:
Where did you order the cooler from...is it decent or Chinese
Stompie
Boostleak Guru
Registered for: 12 years 9 months
Car Model: 2006 120D
Membership No: 1843
Post by Stompie »
The disadvantages of a bigger inter cooler has to be the extra weight!! :lol:
BMW 120D E87
Crispy boss
Car Make: Fiat
Car Model: Bravo Sport
Post by Crispy boss »
What a thread :D
'12 Fiat Bravo Sport 110kw 235nm
Dont take life so seriously
'11 Kia Koup 122kw 203nm
'08 Daihatsu Sirion Sport 1.5 VVTi
'02 Euro Opel Corsa 160is
'85 Opel GSI 2 door Boss
Yakuza Racer
Voora Molester
:hijack:
scottie hooked me up :hurray:
Thupercharged S4
