jetta 5 2.0 tdi no boost at all
- mrf101
- Colon Explorer
- Car Make: AUDI
- Car Model: A4 2.0TDI
- Membership No: 1733
Hey guys, my bro has a jetta 2.0tdi, his car has jus lost all boost, struggln up the hills, there's like jus no power at all durin the rev range, we chekcd for extra smoke outa the exhaust, bt js the same amount that always came out like normal tdi's, wots the possible problems it cud be?
current: daily: a4 b8.5 2.0tdi
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
- Car Make: BMW
- Car Model: 135
- Membership No: 1531
Re: jetta 5 2.0 tdi no boost at all
Weird.
Mine did that, was a boost pipe that popped off. But it looked like night time behind me there was soo much soot.
Just tightened host clamp and all was well.
But with no extra smoke, it's weird what it could be
Current: 2011 BMW E82 135i Alpina White - Stock
ex: 2008 Seat Cupra 1.9tdi Zenith Grey - stock
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=150579
ex:2005 Velociti 1.6i - Dark Metallic Blue (sold)
ex: 2005 Velociti1.4i - White (stolen)
ex: 95' WHITE CITI (i'll always miss you)(blew up)
I'd rather push my VW than drive an Opel
DIE HARD MK1 FAN
DIE HARD MK1 FAN
- Post Whore
- Membership No: 1343
How many KM on the car?
Have you done any work to it recently?
A popped off boost hose would make the car jerk badly and smoke like a putco bus, also fuel consumption would be terrible and it would hiss like a cobra underneath the bonnet.
Have a look at your MAF and MAP sensors, start with the cheap and easy and work your way up to the turbo.
- mrf101
- Colon Explorer
- Car Make: AUDI
no work done onto the car, its stock as can be, i did a scn on vagcom.. showed overboost error.. so i erased all dtc's and drove the car.ruan9n wrote:How many KM on the car?
i fel tt there was sum boost but the car not pulling like how she does, and can hear like a hissing sound that never used to be there before, so im guessing a boost leak sumwhere along the line.
car has 115000kms
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
- Post Whore
Check the turbo outlet boostpipe leading into the cooler, your issue should be there. What happened is a pipe probably popped off or has a tear and the turbo had to work harder to match requested, that sent it into a soft limp.
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
Overboost error is probably not a boost leak. More likely the VNT vanes are stuck, or the actuator is broken or disconnected.
- mrf101
- Colon Explorer
- Car Make: AUDI
ruan9n wrote:Check the turbo outlet boostpipe leading into the cooler, your issue should be there. What happened is a pipe probably popped off or has a tear and the turbo had to work harder to match requested, that sent it into a soft limp.
will check it up...
thanx ruan
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
- Neuk
- Treasurer
- Membership No: 806
First guesses would be the VNT system on the turbo or the vacuum actuator that adjusts the VNT system, either of them not working 100% and you will have boost pressure issues...
- mrf101
- Colon Explorer
- Car Make: AUDI
thanx for the reply guys..
will check up all you guys have suggested.
will give feedback minute the mech has checked the car up.
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
- Post Whore
It is always best to start with the cheap and easy, like jacking the car up and checking from the point of discharge on the turbo to the point of inlet on the cooler for tears and excess oils, if none are there the move on to the point of egress on the cooler to the point of ingress on the motor, if no visible signs of leakage is visible move on to the map sensor which picks up boost, clean it along with the maf. If the issue persists then you have a turbo issue most probably, the garrett turbo's on these aren't too problematic but they have veins on them which become sticky with age as has been said , which may cause the car to boost a lot or nothing.
- Membership No: 388
The vains are easy to check. Jack car up start car.look at the arm on the vacume unit that it sits on its stop.Pull vacume hose off the unit arm must move smooth all the way to its top end position.Tis can be checked by pushing it up with a screw driver.Connect nose and see if it vacumes to its stop again.
G60 16V GOLF
ALDO IS THE MAN WITH A GUN.
THATS HOW WE ROLL [SAINT-J]
- mrf101
- Colon Explorer
- Car Make: AUDI
the turbo is gone..
so will need a new turbo fr the car, and its off motor plan..
any suggestions guys as to where i can get a turbo for this car?
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
weekend: Audi s3 8P
eX: MK6 GTi Revo 3
Membership : #1733
- span die seile
- Membership No: 1746
Hi all. I have a similar issue. No boost. Was advise to see if the car revs to 5100rpm. It dosent. Disconnected the maf sensor still only revs to 3000rpms. Don't know what I'm doing. Also pipe leading to turbo driver side looked like a blocked vacume pipe sucking itself in when I Rev. Is there a vw guy in dbn north Phoenix or verulam that I can go to without getting ripped of. I just got this car..
- BIGMIG
- Porra Love
- Membership No: 1574
Who told you to rev the car that high to check boost my word. If no one offers help go through the vcds register thread and hunt for a person in your area. Get the car scanned. On your side make sure vacuum lines have no cracks. Then go through each boost pipe and look for any Splits also check the rubber seals around the pipe. Any one of those can cause a no boost situation. We all no what happens when we don’t have boost.
Thanks. Will do if anybody out there in the dbn north area can help I would appreciate it. Any recommendations. My no 0678088388. Any help right nw is welcome thanks
guys
guys
