Change oil = turbo blown?
- Voora Molester
So last night i changed the oil on the audi, new oil, new filter...
took the car out and had a good test drive , this morning started the car and the mother **** turbo is blown, like the car doesn't boost and goes into limp mode and is **** up and smoking and there is this sour smell like when you grinding something and and, im so jus for this car..
anyways my questions:
1) was the strain put on the turbo due to the software and the DP?
2) was it just a kak turbo?
3) why is it that after i changed the oil the turbo went? i used the same oil i have always used...
*ps - i need a loan please!!!
**Car is , audi 1.9tdi avant avf 6 speed..
Thupercharged S4
- Neuk
- Treasurer
- Membership No: 806
Re: Change oil = turbo blown?
How much mileage has your car done? Software would place extra strain on the turbo as it is requesting more boost, the DP should have relieved some strain as it would have helped lower EGT's. Unfortunately, turbo's are wear and tear items, they will fail at some stage...
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
How certain are you that it is the turbo?
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- Voora Molester
car as of this morning is 191 000km's...Neuk wrote:How much mileage has your car done? Software would place extra strain on the turbo as it is requesting more boost, the DP should have relieved some strain as it would have helped lower EGT's. Unfortunately, turbo's are wear and tear items, they will fail at some stage...
when we removed the CAT and replaced with DP it was awesome...
now, to fit a bigger turbo or recon and mod the current one? recon is R4600, not sure on price of new one tho', but the recon will be done by Oom Kallie and will mod the turbo (bigger exhaust thingy and something...)
apparently the shaft is VERY loose and the "blades" (?) is damaged...
@1.9T= VERY certain...
Thupercharged S4
- Neuk
- Treasurer
Sounds like wear and tear to me, or the shaft snapped? Once you get a bit of movement, blades start touching the housing, waer themselves, go out of balance and well...yakuza racer wrote:apparently the shaft is VERY loose and the "blades" (?) is damaged...
P.S. Perfect time to go for something bigger though...
- Voora Molester
Thupercharged S4
- AlexTDi
Phone VW if it's the same turbo as we have on the ASZ motors (pTDI S/L) It is something like 3600 or 3800 brand new from the dealers.
Some VW's don't have the cheaper price so you might need to phone VW Hatfield Bryanston
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Voora Molester
appreciate it man!1.9TurboVw wrote:Phone VW if it's the same turbo as we have on the ASZ motors (pTDI S/L) It is something like 3600 or 3800 brand new from the dealers.
thanks
Thupercharged S4
- AlexTDi
forget this thread: http://www.vwclub.co.za/phpbb3/viewtopi ... lit=+turbo
and this one: http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=153051
So R4100 inc vat
So R4100 inc vat
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Neuk
- Treasurer
If it were me, and it was my daily, I wouldn't go mad so something like the VNT1749Vb from the SEAT IC TDi or the turbo that carapau used in his SEAT IC TDi but those are both used in transverse fitted engines so may need some work. Your best bet may be what you described above, recon yours so you keep the same housing but going for something larger...yakuza racer wrote:any recs?Neuk wrote:
- Neuk
- Treasurer
Just check fitment, A4 engine is fitted inline, not transverse like VW's, except for the Passat...yakuza racer wrote:appreciate it man!1.9TurboVw wrote:Phone VW if it's the same turbo as we have on the ASZ motors (pTDI S/L) It is something like 3600 or 3800 brand new from the dealers.
thanks
- Car Model: '13 PGTI DSG
Apparently when a turbo is going or about to go it is very loud ie the shaft and props are touching the inlet but it could be possible the shaft snapped due to high heat etc also they say just be careful nothing went through the system ie metal parts or shavings.They also say it usually puffs smoke or screeches, you will know its blown lol.Most common failure of the tubo is the cooling and lubrication maybe the oil line had a block?
- Voora Molester
the done this!!RPGTI wrote:Apparently when a turbo is going or about to go it is very loud ie the shaft and props are touching the inlet but it could be possible the shaft snapped due to high heat etc also they say just be careful nothing went through the system ie metal parts or shavings.They also say it usually puffs smoke or screeches, you will know its blown lol.Most common failure of the tubo is the cooling and lubrication maybe the oil line had a block?
checking it all out, appreciate the feedback. How do i check if stuff went through the system?
Thupercharged S4
If you loosen or take off one of the boost pipes closer to the throttle body and see any traces of little shavings it could be possible that they went into the motor.Im not sure how bad little shavings will be but I can only imagine large pieces or a fair amount of little shavings will cause a issue but I believe the shavings and pieces are only in bad situations.
- Voora Molester
ah, ok cool.. thanks manRPGTI wrote:If you loosen or take off one of the boost pipes closer to the throttle body and see any traces of little shavings it could be possible that they went into the motor.Im not sure how bad little shavings will be but I can only imagine large pieces or a fair amount of little shavings will cause a issue but I believe the shavings and pieces are only in bad situations.
Thupercharged S4
- Tdi jetta 4 ever
When last did you change the air filter?
Robin
robinwisse@gmail.com
- BIGMIG
- Porra Love
- Membership No: 1574
That's almost exactly what I did when I replaced the transporters turbo at work but instead of looking at the boost pipe by the throttle I looked at the ore FMIC boost pipe and there where bits of the blown impelers everywhere and a crap load of oil spilled out the pipe as I took it off.RPGTI wrote:If you loosen or take off one of the boost pipes closer to the throttle body and see any traces of little shavings it could be possible that they went into the motor.Im not sure how bad little shavings will be but I can only imagine large pieces or a fair amount of little shavings will cause a issue but I believe the shavings and pieces are only in bad situations.
- J-10-M
- Car Model: MK5 GTI
Subaru.... the end
- Neuk
- Treasurer
Yeah, ask JaredS how his Subaru is doing...J-10-M wrote:Subaru.... the end
