How much boost is "safe" on a Mk4 TDI
- Scatman
- General
- Car Make: BMW
- Car Model: 320d Msport
- Membership No: 1773
Hi guys, I plan on getting software sometime in the future, I'd just like to hear what you guys have to say regarding the highest boost I can run without causing problems with reliability? From what I've read on other forums, 1.3-1.5Bar is the general average? I don't drive the car hard often, but I do give it stick at least once every time I drive it.
Also, would I need to do something to the diesel pump or injector nozzles, and will the stock intercooler be able to cope with cooling 1.5Bar of air? Thanks in advance
2008 BMW 320d Msport Auto
2006 Audi A3 2.0T
2006 BMW E90 330d Manual
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- ShaneTdi
- Registered for: 12 years 3 months
- Car Model: Golf Mk6 GTI
- Membership No: 1735
Re: How much boost is "safe" on a Mk4 TDI
I think you should be safe with about 1.3Bar as that is about the increase you get from a very mild map.
- Scatman
- General
- Car Make: BMW
Panic said he ran a 1.5Bar map on his two Mk4 Jetta TDI's, and he had no problems whatsoever. I would just like some more input on the subject. 1.3 Bar doesn't sound like a big leap in terms of performance, as I am currently boosting around 0.9Bar.
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Remember its a diesel, you need fuel to make power not air. Boost is just there to reduce the smoke.
If you really wana go mad then import some bosio nozzles slap on a cupra turbo and smile to 180whp.
- ShaneTdi
Killerwatt wrote:Remember its a diesel, you need fuel to make power not air. Boost is just there to reduce the smoke.
Now that would make a killer diesel.....
- M@rk
- Car Model: 1.9 Tdi Sportline
- Membership No: 1776
Now this man speaks the truth ..Killerwatt wrote:Remember its a diesel, you need fuel to make power not air. Boost is just there to reduce the smoke.
Boost only Reduce smoke..
But 1.5 bar is perfect
- carapau
- Car Make: Seat
- Car Model: Ibiza Cupra Tdi
+1
1.5bar maximum. Also a cooler is always a great mod to do
- Scatman
- General
- Car Make: BMW
Okay done deal! 1.5Bar it will be. I'll do fmic at a later stage (next summer). I heard the automatic TDI Jetta's use 11mm lines/whatever as compared to my 10mm. What are they on about?
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- Sinbad
- Post Whore
- Car Make: Mercedes
- Membership No: 1152
NO NO NOTdi_WhiteShadow wrote:Now this man speaks the truth ..Killerwatt wrote:Remember its a diesel, you need fuel to make power not air. Boost is just there to reduce the smoke.
Boost does NOT reduce smoke.
Well yes it does, but that's not the reason for it. Diesels rely on excess air for cooling the combustion chamber. Running too rich raises EGTs too high and will cause kak down the line.
Cupra boosts 1.55 stock, 1.9 with a remap just btw.
- Neuk
- Treasurer
- Membership No: 806
1.5 bar is fine for those motors...
Take a look at the http://www.tdiclub.com/ forum, there is a ton of information about modifying the VE series of TDi engines...
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
That fuel pump is good for over 200hp.
your cooler is also thicker than teh sportlines one so should handle it fine.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Not lines, that's the pump piston diameter. Basically bigger pump, more fuel and more power. But that only becomes an issue if you run some big nozzles. There was also a company that made 12mm pumps.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Sinbad, you are correct but injecton timing, boost, smoke and egts are all interlinked. Iirc, you get smokey before egts become an issue.
- M@rk
Scatman don't get to technical about it ..forget about egt's biger turbo's how much it smokes or how much it boost and all of that **** ...Scatman wrote:Hi guys, I plan on getting software sometime in the future, I'd just like to hear what you guys have to say regarding the highest boost I can run without causing problems with reliability? From what I've read on other forums, 1.3-1.5Bar is the general average? I don't drive the car hard often, but I do give it stick at least once every time I drive it.
Just do a mild map software (1.3-1.5) a decat ,and Fmic then you will be good to go.
Unless you want to go big the you get technical.
Just my 2c
- Killerwatt
- Car Make: AUDI
- Car Model: S3
yeah dont over think it yet, do tried and trusted mods and all will be good.
But check out Neuk's link, crapload of knowledge there.
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
- Scatman
- General
- Car Make: BMW
Thanks for the info guys, finally I know what the 10.11mm refers to. I already have decat and mufflerectomy, so that should possibly help with EGT's a little? I reckon I'll get the map to run 1.5Bar and maybe look at a fmic if the heatsoak is bad. The Jetta has a nice and thick intercooler, and I have done the vent mod which reduced heatsoak a great deal also. Thanks for the help and info guys, I really appreciate it!
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
2006 Audi A3 2.0T
*Click here*
2006 Sportline
*Click here*
*Click here*
*Click here*
2005 1.4i Citi Golf
*Click here*
- carapau
- Car Make: Seat
Sinbad wrote:NO NO NOTdi_WhiteShadow wrote:Now this man speaks the truth ..Killerwatt wrote:Remember its a diesel, you need fuel to make power not air. Boost is just there to reduce the smoke.
Wanna beat it reduces smoke?
- Sinbad
- Post Whore
Read my whole post and try again
- carapau
- Car Make: Seat
;} most people think otherwise
- 4ePikanini
- Car Model: Touareg R5
best bang for buck is to have a freeflow de-cat and a remap. (possibly a FMIC)
- BIGMIG
- Porra Love
- Membership No: 1574
Sorry but the statement that you need fuel to make power not air is utter crap. They work hand in hand with each other. The smoke is a nasty mix which also contains unburnt fuel. So to help burn fuel more effectively you add boost. That is how it makes it smoke less because the fuel is being burn more efficiently
- Tdi jetta 4 ever
Finally, someone who speak more sense.BIGMIG wrote:Sorry but the statement that you need fuel to make power not air is utter crap. They work hand in hand with each other. The smoke is a nasty mix which also contains unburnt fuel. So to help burn fuel more effectively you add boost. That is how it makes it smoke less because the fuel is being burn more efficiently
Robin
robinwisse@gmail.com
- Committee Member
- Car Model: Audi S3 Sedan
- Membership No: 1215
^This!!^
Martin, As I told you before, Take your car to a professional (Trevor) and let him do his thing. He will dyno the car and work out what works best and gains the best result.
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
- BIGMIG
- Porra Love
What do you mean? Are you trying to say this guy? whyG-Spot wrote:^This!!^
