My ex cupra polo FMIC pics...
- Post Whore
- Membership No: 1343
What you need...
Had to mount it skew because of the style bumper and the boost pipes.
- Scotty_88
- Car Model: Polo TDI sportline
Re: My ex cupra polo FMIC pics...
what is the size of that cooler? I am looking at doing a cooler on my 9n3. know it is less hassle than the 9n to fit too. Came across a cooler which measures 725x300x75, just scared its a bit too big for my TDI
- dhirennaidoo
- Car Model: 9n Polo Classic TDi (PD100)
Thank You kind sir!
'08 350Z
'05 Polo Classic TDi (PD100)
Ex : '12 Mk6 GTi Ed35, '91 Fox 1.8, Honda CBR600F, '09 Honda CBX250 Twister
- Post Whore
I think the size was 450x230x65 I guess 550x180x65 would be ideal!
Just to add....I also installed a cupra 2.5bar map sensor with this.
- Neuk
- Treasurer
- Membership No: 806
Ruan, its skew, will most likely lead to a blown turbo...
- Post Whore
Don't BLOW things out of proportion NikolaiNeuk wrote:Ruan, its skew, will most likely lead to a blown turbo...
- Post Whore
I did...shaneskip wrote:Did you do this yourself Ruan?
- ShaneTdi
- Registered for: 12 years 3 months
- Car Model: Golf Mk6 GTI
- Membership No: 1735
Nice work then… if I may ask why dis tou not fit a u-flow type cooler?
- Post Whore
Because this cooler cost me R1000 at volkspares and back when I did this U flow coolers weren't as freely available as they are now.shaneskip wrote:Nice work then… if I may ask why dis tou not fit a u-flow type cooler?
- ShaneTdi
Ah I see I have done software and went to do some logs with Teitlist the other day my intake temps were mad high and I need a cooler upgrade early next year and was going to get a u-flow from Mr.Turbo as they are now priced at around R1200.
- Deranged_9n3
- Darth Vader
- Membership No: 1639
Is stock map sensor 2.0bar ??ruan9n wrote:I think the size was 450x230x65 I guess 550x180x65 would be ideal!
My Youtube Channel
Tiguan Track & Field 4Motion
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
Loud 'n Low, Rollin' Coal
Polo TDi RaceCar
GTB2260VZK
13.2 1/4mile @ ODI
- Neuk
- Treasurer
I believe that my hindsight is 20/20...ruan9n wrote:Don't BLOW things out of proportion NikolaiNeuk wrote:Ruan, its skew, will most likely lead to a blown turbo...
- Post Whore
Yes... had the 2.5bar cupra map sensor installed and "coded" into the software when the cupra turbo went in. If you spike over 2 bar when at the coast limp mode...1FlyTDI! wrote:Is stock map sensor 2.0bar ??ruan9n wrote:I think the size was 450x230x65 I guess 550x180x65 would be ideal!
- Post Whore
Ja nee that little tdi turbo said hello to 2bar and hello to 220kmh and said totsiens to its exhaust wheel, the intake wheel went and sat nicely in the corner of the housing too. I actually had the clocks fullNeuk wrote:I believe that my hindsight is 20/20...ruan9n wrote:Don't BLOW things out of proportion NikolaiNeuk wrote:Ruan, its skew, will most likely lead to a blown turbo...
- ShaneTdi
I have only taken mine to 190 then I tap off to 160 as I feel a fear of my turbo waving goodbye.......
