MAF sensor for Jetta 4 TDI
Hi,
I suspect my MAF sensor on my Jetta 4 TDI is not working properly. When I am travelling and suddenly press the gas pedal it takes a long time to accelerate, it used to be quick. Also my fuel consumption seems to be slightly worse than normal.
Last one I put in was a reconditioned unit, installed it about 3 or 4 years ago.
Any idea where I can find a MAF sensor new for a good price in Pretoria/JHB area?
dirkme
2001 VW Jetta TDI (Current)
1983 VW Jetta GLI (Sold)
- Dirty Harry
- Car Make: People Carrier
- Car Model: footswagen
- Membership No: 1640
Re: MAF sensor for Jetta 4 TDI
You can get a bosch unit from goldwagen for about R1200
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Unplug ad see if it feels better.
check diesel electric too, they are always cheaper than goldwagen.
- FM1
- Car Make: Ford
- Car Model: Fiesta
im too in this same boat,except im driving a 1.6. i tried unplugging my maf but the car wouldnt even want to move a 100m
FROM ROOTS TO TREETOP
Current: Ford Fiesta
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- FM1
- Car Make: Ford
- Car Model: Fiesta
so im not sure if my maf is broken or if its an airleak somewhere. maybe check your hoses if theres any air escaping
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
Hi, thanks. Do you have their contact details? Do they also sell the bosch unit?Killerwatt wrote:Unplug ad see if it feels better.
dirkme
- FM1
- Car Make: Ford
- Car Model: Fiesta
if it may help please see this FAQ
http://uk-mkivs.net/forums/t/56052.aspx
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- Killerwatt
- Car Make: AUDI
- Car Model: S3
yup its a bosch unit. nuber for the pretoria branch (012) 327 4810
Maf on the tdi is basically there for the smoke control, if it reads low then it will limit fuel and thus decrease performance. when you unplug it it defalts to a certain value so performance is unaffected. thats why i said unplug it and see if it runs better.
on the 1.6 you have no wideband so unpluging it would undoubtably make the car run like crap.
- FM1
- Car Make: Ford
- Car Model: Fiesta
thanks for this infoKillerwatt wrote:yup its a bosch unit. nuber for the pretoria branch (012) 327 4810
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- carapau
- Car Make: Seat
- Car Model: Ibiza Cupra Tdi
I have one from the Cupra if u cant get
- FM1
- Car Make: Ford
- Car Model: Fiesta
assuming this post is for the guy with the tdi?carapau wrote:I have one from the Cupra if u cant get
Ex: VW Golf 4 1.6
Ex: VW Golf 4 1.6
- carapau
- Car Make: Seat
Thanks, will get one at goldwagen, they have stock. Will let you know if this changes.carapau wrote:I have one from the Cupra if u cant get
dirkme
- VELO-GP
- Car Model: MK4 GTi
- Membership No: 1870
diesel electric are bosh agents and not too pricey
R300 cheaper at goldwagenVELO-GP wrote:diesel electric are bosh agents and not too pricey
dirkme
I drove home with the maf unplugged. No change in power, slightly worse fuel consumption. There was no error given on the dash. Is that correct?
dirkme
- Tdi jetta 4 ever
That correct yes. It wont give a error on the dash.dirkme wrote:I drove home with the maf unplugged. No change in power, slightly worse fuel consumption. There was no error given on the dash. Is that correct?
Have the car scanned to double check what the fault may be.
Robin
robinwisse@gmail.com
- carapau
- Car Make: Seat
If theres no change in power then its the maf
Cool, one more question, should i clean the intercooler to prevent more oil from spoiling it? Car has just under 290 000 km on it.carapau wrote:If theres no change in power then its the maf
dirkme
- carapau
- Car Make: Seat
theres oil spoiling ?
MAF sensor and cooler have nothing to do with each other ,but its always good to have the cooler nice and clean
- Killerwatt
- Car Make: AUDI
- Car Model: S3
I disagree with this, if there is no change then how can it be the maf?carapau wrote:If theres no change in power then its the maf
- carapau
- Car Make: Seat
coz when u unplug the maf the car goes flat
- Killerwatt
- Car Make: AUDI
- Car Model: S3
okay then, thought it was the other way around with the tdi's...
- Tdi jetta 4 ever
Correction. When my MAF packed up the car was dead up to about 2500 rpm then suddenly the turbo kicked in for a short while. When i unplugged the MAF the car pulled way better and more like it supposed to be. But MAF's also give different symptoms when they pack up.
Robin
- Killerwatt
- Car Make: AUDI
- Car Model: S3
thats how i knew it...
