Warning light on dash??? *low pads*
- Dougi
- Broekn Neuws Reportr
- Car Model: Seat Ibiza Cupra, TDI
- Membership No: 1662
Hi all
So on the way to gym this morning at 4:30 on the high way in my 1.9tdi and after not driving it this whole week i thought i would burn it.
So i hit a speed that of x00kph and the Brake pad wear indicator light came on.
The thing is that the pads were replaced about 3 months ago.
what else could this be?
- Registered for: 20 years 3 months
- Car Model: Amarok V6
- Membership No: 664
Re: Warning light on dash???
Check the wires for the pad wear indicators...
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
VW Polo 2.0 Highline
BMW E90 320D
VW Caddy 2.0 8V
Nissan X-trail 2.0 dCi
VW Jetta 2.0 16V Turbo
VW Polo 1.6 Comfortline
BMW 335
Audi RSQ3
CURRENT CARS
VW Amarok V6 Exstream
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Dougi
Thanks. I will look could this also be brake fluid?joggiep wrote:Check the wires for the pad wear indicators...
Could but it would be low then.. so easy to spot.
Little sensor/wire that earths will also cause the light to come on.
Joggie Pretorius
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
EX - CARS
Jetta CSX 1.8 8v
Golf CTi 1.8 8v
Polo 1.6 lux
SEAT Ibiza Sport
BMW E90 320D
VW Caddy 2.0 8V
BMW 335
Audi RSQ3
CURRENT CARS
- Car Make: Mercedes
- Car Model: AMG
- Membership No: 1368
More than likely low fluid.
.....Past Volvo S70R (GT3582R modded), Volvo XC70, Volvo 850 T5, VW Jetta VR6 (Rebored), VW Jetta CLX, VW Golf II GTS
Present Mercedes ML500, Mercedes SLK32 AMG
.Project '74 W114 Benz
- Dougi
I have a feeling it could be where the pad indicator on the pad itself has a plug and the plug connects to the one to the car could be the issue as the car plug was ****. so will check it all the weekend and then see if I can get a new one
and solder a new one on
- ShaneTdi
- Car Model: Golf Mk6 GTI
- Membership No: 1735
Could be dirt on the sensor that happened to me break cleaner resolved it after a good soak and rinse.
- Dougi
Just went to go look and its fullKibim wrote:More than likely low fluid.
- Dougi
are you referring to the ABS sensor?shaneskip wrote:Could be dirt on the sensor that happened to me break cleaner resolved it after a good soak and rinse.
if yes then the ABS light would come on. and they were also cleaned about 3 month back
- Dougi
So ill be scanning the car tomorrow after work and will just drive the wifes car tomorrow.
- Car Make: Jaguar
- Car Model: X-Type 2.2D
Won't low brake fluid rather trigger the brake warning light?Kibim wrote:More than likely low fluid.
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Ex: 2000 Citi 1.3
Pad sensor wire most likely broken. If the brakes are working and there is no grinding there is no reason not to drive it.
- ShaneTdi
Mine had dirt in it that supposedly caused static to give error signals. weirdest thing I ever heard but a Mechanic told me that and I had them cleaned and poof problem gone.Dougi wrote:are you referring to the ABS sensor?shaneskip wrote:Could be dirt on the sensor that happened to me break cleaner resolved it after a good soak and rinse.
- B_rad
- Car Make: Ford
- Car Model: Fiesta ST180
- Membership No: 1835
These brake sensors are the biggest waste of time IMHO
Mine came out after replacing the pads. there is one on the right front and rear left. check those. I just pushed the two wires together and taped it up
- Sparkz0629
- Car Model: 2012 Polo GTI
- Membership No: 1768
I had the exact same thing... lols
The cables to the sensor had been ripped off by something... they reconnected, and all good...
Current: 2012 Reflex Silver 6R Polo GTI
2006 1.9TDi Sportline - 158.7Hp & 413Nm at K.A.R 19-05-2012
VWicked wrote: I could do 300km/h if I wanted but I don't trust my brakes stopping from that speed so as soon as i hit exactly 241km/h on my garmin i will tap off, generally it takes me me 6.9 sec to get there so I will just cruise the last 5 sec's to allow the car to cool down..
- Dougi
Thanks Oom panic, I only sow your post now.
So I want to Tiaan and we scanned the car and cleared and the error kept comming back.
This error is saying the I have low pads.
So as some of you know the wires that connect to the pad have a comment issue on the polos.
So I will make a plan this weekend and ill get to a scrap yard and get newer plugs and fix.
Thanks for the help all.
- MeanTdi
- The Imposer Mod-whore-rator
- Registered for: 18 years
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
So this warning light came up last night.
Now I can finally change brake pads and discs. OEM ones lasted 90 000klms from when the car was bought from new.
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- Dougi
Re: Warning light on dash??? *low pads*
wow nice. did you put the new disks on too?
- Sparkz0629
Dan, did you check your pads/sensor?
- Puni
- Car Model: Touareg V10
- Membership No: 1523
You have never changed discks or pads?MeanTdi wrote:So this warning light came up last night.
Derrick Puni Brummer
'08 Touareg V10
'11 CC 2.0 TDI DSG
'17 T6 Kombi 2.0 TDI
Puni's GTI
Puni se Polo
'04 Chico Golf
VWCSA Membership Number: 1523
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
- Dougi
yes I did, the pad indicator plug pulled out so it is now fixedSparkz0629 wrote:Dan, did you check your pads/sensor?
- Car Make: Cheap Ass Porsche
- Car Model: 9N Sooter
- Membership No: 807
My rear disks and pads lasted 195000km. Current set of front disks and pads (PowerBrake/Ferodo Premier) are at 133000km. Still no warning light.Puni wrote:You have never changed discks or pads?MeanTdi wrote:So this warning light came up last night.
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
I didnt read all the posts but had the same issue, basically new pads but the sensor broke off, so I just opened it up, check if alles was ok and then bridged the wires and drove the car for ages until it was sold.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- Puni
Thats flippen good.VGTI wrote:My rear disks and pads lasted 195000km. Current set of front disks and pads (PowerBrake/Ferodo Premier) are at 133000km. Still no warning light.Puni wrote:You have never changed discks or pads?MeanTdi wrote:So this warning light came up last night.
I brake to hard for it to last that long.
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
'08 Touareg V10
'11 CC 2.0 TDI DSG
Puni's GTI
Puni se Polo
'04 Chico Golf
- VWicked
VGTI doesnt brake, his car slows down using air resistance - only a master of fuel consumption can achieve that
