Sweet, keep us updated.T@nk wrote:Thank you for the input, I have had my car at a guy that is a mechanic at Audi, he recommended me to check the cam timing and EGR valve. My car is going in for cam belt service on the 2012-10-22, so all this will be checked and hopefully it all will be sorted. Viper please be on standby, we gonna need some parts... lolGino1001 wrote:Hi guys,
I have the Le Mans that's known for its horrible lag; I bought mine second hand and also thought that the vanes might be stuck. So, after alot of researching and replacing quite a few parts (mostly under FWP), my lag is finally gone.
Although replacing the EGR valve was worth it in terms of smoothness, the two things that really made all the difference was:
1. Replacing the boost pressure sensor &
2. Software - tuner was able to shift the torque band by a couple of 100 rpms which means no lag in any gear through most of the rpm range.
Just my 2c
Will see what the conclusion is and give you guys some feedback.
No low end torque - Audi A4 2.0TDi
- Car Model: Polo 2.0
Re: No low end torque - Audi A4 2.0TDi
'10 Audi A5 2.0T Sportback
'06 Polo 2.0 Highline
'88 Chisel RSi
'88 Chisel RSi
Ok, so completely might not have been the right word to use, but its 200% beter than what it was.Neuk wrote:I don't believe you can ever get rid of lag completely, you can improve it but due to the fact that you have to get the turbo up to its optimum rpm when going from off throttle back to on, lag will never be completely over come...Gino1001 wrote:Hi guys,
Just my 2c
My car used to stall quite easily on pull-off but now I no longer have to give a bit of gas when pulling off slowly.
The worst was taking a turn and having to go down to 2nd gear especially if there was a bit of an incline, it would go nowhere veeeerrrrryyyy slowly.
On cold/chilly evenings, acceleration is instant - might be the software
'88 Chisel RSi
'88 Chisel RSi
- Wheel Whore
- Car Model: Passat 2.0TDI
- Membership No: 3127
Just want to say thanks to those that helped!
managed to get Glow Plugs from Goldwagen at R219 each
car will be back in my hands tomorrow
Great service from Goldwagen contacted them last week said they didn't have but today they phoned me back and got them in for me
- Neuk
- Treasurer
- Membership No: 806
Cool, but, the highlighted part isn't lag, that's boost threshold The gearing down you described would be lag...Gino1001 wrote:Ok, so completely might not have been the right word to use, but its 200% beter than what it was.Neuk wrote:I don't believe you can ever get rid of lag completely, you can improve it but due to the fact that you have to get the turbo up to its optimum rpm when going from off throttle back to on, lag will never be completely over come...Gino1001 wrote:Hi guys,
Just my 2c
Thanks mr Neuk
'88 Chisel RSi
'88 Chisel RSi
- Neuk
- Treasurer
:high five:Gino1001 wrote:Thanks mr Neuk
Sent from my iPhone 4 using Tapatalk
- Wheel Whore
Thought i'd update you guys
got my car back , new glow plugs in
and no lights are appearing on my dash so looks like it was the Glow Plugs ,very odd thing to cause such a thing
well yeah now its back to normal will fill up soon and keep T@nk updated on how many km's i get
- Neuk
- Treasurer
Great successeliasTDI wrote:Thought i'd update you guys
- T@nk
- Car Model: A4 (B7) 2.0TDi
- Membership No: 1954
Would just like to inform you that my Audi is going like a dream again. The mechanic told me that when he put the new cam-belt on he adjusted the pulley's so they are aligned again. I still have a-bit of a dead spot at low end, but it starts to push you into the seat from about 1500 rpm. Very happy...
Thank you for all the help and advice.
Now I just want to take it to Revo to get the software done...
“The best thing about a boolean is even if you are wrong, you are only off by a bit.”
- Neuk
- Treasurer
Good to hear, boosting from around 1500 rpm is on the low side but n0ot abnormal on a TDi...T@nk wrote:Hi guys
Now I just want to take it to Revo to get the chip software done...
- Tdi jetta 4 ever
So with other words the timing was a bit out?
Robin
robinwisse@gmail.com
- T@nk
Jip... But he said it wasn't out by a lot.
- Tdi jetta 4 ever
Great, glad you came right.
Robin
- Neuk
- Treasurer
Won't have to be out by a lot to have a noticeable effect. Many forget that timing in a TDi is massively important, especially fuel injection timing...T@nk wrote:Jip... But he said it wasn't out by a lot.
Glad you got sorted T@nk; its actually good to know as I also need to replace my cam belt in the next couple of months.
'88 Chisel RSi
'88 Chisel RSi
- Car Make: BMW
- Car Model: 135
- Membership No: 1531
You are the second person to say stick 2 stroke oil with a tank of diesel, should it be used as preventitive maintenance at all, say stick it in once every 4 fill ups or so?4ePikanini wrote:this is how the vanes work
check for the linkages around the turbo and make sure there are no vacuum leaks or loose conectors (I don't know if the 2.0Tdi VGT is vacuum or electrical operated)
If you can get access, spray the outside of the turbo where you can see linkages thoroughly with tool-in-a-can/wd40/q20.
Leave overnight. The next day you wash off the residual oil with warm soapy water.
Chuck a 250ml 2SO (2 stroke oil - it burns away carbon deposits at low ratios) in a full tank of diesel and drive the car hard for the next tank (observe the law and remember cool down period when stopping for the turbo).
http://www.disco3.co.uk/forum/topic79420-120.html
http://www.4x4community.co.za/forum/sho ... hp?t=96797
Current: 2011 BMW E82 135i Alpina White - Stock
ex: 2008 Seat Cupra 1.9tdi Zenith Grey - stock
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=150579
ex:2005 Velociti 1.6i - Dark Metallic Blue (sold)
ex: 2005 Velociti1.4i - White (stolen)
ex: 95' WHITE CITI (i'll always miss you)(blew up)
I'd rather push my VW than drive an Opel
DIE HARD MK1 FAN
DIE HARD MK1 FAN
- dazza
- Car Make: VW and VW
- Membership No: 1327
1500rpm and you have boost already... thats very low you should be happy with that...These cars share the same turbo as the Ibiza Cupra and they are known to be more laggy than say a sportline turbo
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- T@nk
Hi Guys
Just want to give an update.
I did report to you that I have changed the Cam-Belt and the problem nearly went away, because the timing was out a bit.
Well my car started to get heavy on juice and smoking a lot, so I sent it to get the Injectors checked, and ended up Reconditioning them.
R8k later and I must say my low end torque problem and sluggishness at low RPM is a thing of the past. It almost feels like a new car again.
Thanks for all you guys help, very much appreciated.
Regards,
Herman
Regards,
Herman
- Neuk
- Treasurer
R8k isn't too bad as long as the injectors are good for a few more years They cost a bloody fortune...
- T@nk
Yah, I thought so as well. Got quoted R12k each for new ones. That would have been painfull.Neuk wrote:R8k isn't too bad as long as the injectors are good for a few more years They cost a bloody fortune...
- Neuk
- Treasurer
It is the major downfall of the PD based TDi's, the bulk of the engine's are bomb proof with a few issues here and there but replacing injectors, eish...T@nk wrote:Yah, I thought so as well. Got quoted R12k each for new ones. That would have been painfull.Neuk wrote:R8k isn't too bad as long as the injectors are good for a few more years They cost a bloody fortune...
Online
- Silverbird_96Kw
- Car Model: Mk7 Golf R
- Membership No: 1643
Glad to hear your sorted now - We als have a 06 Audi 2.0TDI Multitronic and our issue is:
When I put the car in "Sport" or either "Manual" and put my foot down the car has a Shudder/jerk feeling and car doesn't perform like it use to (lacking in power)...
When it gets to 2500rpm / 3000rpm it feels and looks like the car gets stuck at those refs - the needle moves soooo slow
When booting it in normal drive the car will do exact same. When one drives normally in "Drive" there is no shudder jerk as the car doesn't reach high revs.
It is as if its only doing that shudder when you put your foot down to accelerate quicker. Its hard to explain lol.
Last year the car made a funny sound when starting so we took it to a mechanic and he said its the flywheel in the gearbox. So car was taken to Audi Northcliff and they also started the car (makes a grinding noise) they also confirmed its the flywheel so they had the car for a few days taking the box apart and found no faults, but they did replace that in the end of the day after some fighting as the car JUST came out of motorplan (120000km). End of the day that (grinding noise when starting) problem was a faulty battery.
And that's the only big thing that happened. Rest of the time car was serviced normally. Car has 161000km on
15 VW Golf R
15 VW Passat 2.0TSi Rline
17 VW Polo 1.2TSi Highline
17 VW Golf Mk7.5 GTi
15 Audi A3 Sedan 1.8TFSI Stronic
11 VW Roc 2.0TFSI DSG
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
12 VW Golf 6 1.4 TSI Comfortline
06 Vw Polo 1.9 TDI Sportline
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
- Tdi jetta 4 ever
Did the shudder disappeared after the new battery?Silverbird_96Kw wrote:Glad to hear your sorted now - We als have a 06 Audi 2.0TDI Multitronic and our issue is:
Robin
Online
It is as if the boost doesnt kick in, if one is on a long road and doing 90 behind a truck and them want to overtake - you can barely do it, as it takes long just to get to 110
- Silverbird_96Kw
No only the grinding noise when the car started.Tdi jetta 4 ever wrote:Did the shudder disappeared after the new battery?
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
Online
- Silverbird_96Kw
So I took the Audi to KAR and this is the result...
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
