2019 Polo 1.0 Tsi vibration and idle shaking
Membership queries? More info? Problems? Post here and the Committee will get back to you
This is NOT for technical or brand-related questions.
Viruz187
Post by Viruz187 »
Hi All.
Trust you are well and safe.
I'm a newbie and would like some advise or even a solution for what I'm experiencing.
I'm from Durban and own a 2019 Polo 1.0 TSI Trendline.
I've noticed that between 0 and 2000 rpm, there is a vibration on acceleration. This happens @ every gear. As soon as it's above 2000 rpm the vibration goes away.
I've taken the vehicle to the VW in Umhlanga and they checked everything and it came back as the vehicle is within spec and could not find a fault.
It's so annoying to feel this vibration at each gear change.
Also noticed that when the vehicle is on idle, it shakes Abit. It's sort of when you in the vehicle or outside with a hand on the vehicle you can feel this shaking. The starting up has no issues, it's just when it idles. I read somewhere it could be a bad spark plug.
Some advise would be really appreciated guys.
Thank you.
POLOBOYSA
Re: 2019 Polo 1.0 Tsi vibration and idle shaking
Post by POLOBOYSA »
im sitting with the same issue but on a 2005 polo 1.9TDI came here to find a solution
Viruz187
Post by Viruz187 »
Did you always have this issue or is it something new?
I thought I would get advise on the forum, but seems as my problem might be a unique one seeing as I haven't gotten any other responses.
Let me know if you come across any fix. I will do the same.
NHB_R
Post by NHB_R »
Is it a manual or auto?
Viruz187
Post by Viruz187 »
Hi, yes it's a manual
